TCP Connection
The TCP Connection plugin turns IO Ninja into a raw TCP terminal, allowing you to connect to network nodes, send custom packets, and analyze responses. It lets you prepare packets in binary mode with a hex editor and provides detailed logging and transmission capabilities. You can also configure aspects of the TCP socket, such as the local interface, port, Nagle’s algorithm, and how connections are closed. This makes it a practical tool for exploring network behavior and testing TCP communication.
In IO Ninja, click the “New Session” dropdown and select “TCP Connection”.
Set your target address/port and click “Connect”.
Use the “Transmit” pane to craft a custom packet, and then press send.
Remote port to connect to in cases when a port is not explicitly specified in Remote address. |
80 |
Reconnect |
Attempt to reconnect when connection is dropped by the remote node. |
Reconnect timeout |
The delay between reconnect attempts. |
3000 |
Use local address |
Bind socket to the specified local address. |
An example of an adapter dropdown on a typical Windows laptop is shown below:
