SSL Connection
The SSL Connection plugin turns IO Ninja into a highly configurable raw SSL client-side terminal.
In IO Ninja, click the “New Session” dropdown and select “SSL Connection”.
Type your remote address e.g. “ioninja.com” and click “Connect”.
You can expand SSL certificates by pressing the [+] button, and even copy the PEM blob.
Send packets using the “Transmit” pane and see responses in the log.
For basic testing, you can try to pull IO Ninja’s logo with the following GET packet:
GET /images/icons/ioninja-256x256.png HTTP/1.1
Host: ioninja.com
Remember to add two blank lines after the last header line to indicate the end of the request.
Remote port to connect to in cases when a port is not explicitly specified in Remote address. |
80 |
Reconnect |
Attempt to reconnect when connection is dropped by the remote node. |
Reconnect timeout |
The delay between reconnect attempts. |
3000 |
Use local address |
Bind socket to the specified local address. |
Security level |
Specify OpenSSL security level. Read more about OpenSSL security levels here. |
1 |
Cipher suite |
Select an OpenSSL cipher mode. OpenSSL ciphers refer to the cryptographic algorithms supported by the OpenSSL library for securing data in transit, typically over SSL/TLS connections. Read more about OpenSSL ciphers here. See avaialble options. |
ALL |
Use certificate |
Whether or not to use a client-side certificate for the SSL connection (PEM format). |
Certificate |
Specify the file path of the client-side certificate (PEM format). |
Private key |
Specify the private key for the client-side certificate (PEM format). |
Verify certificates |
Whether or not to verify the server-side certificate of the target SSL server (PEM format). |
CA certificate |
Specify the file path of the server-side CA certificate to be used for verification (PEM format). |
CA directory |
Specify a directory of server-side CA certificates to be used for verification (PEM format). |
Verify depth |
Specify the maximum certificate certificate chain length. A certificate chain is a sequence of certificates—starting with the SSL/TLS certificate and followed by one or more Certificate Authority (CA) certificates—that allows the recipient to verify the authenticity and trustworthiness of both the sender and the issuing CAs. |
10 |
Pass hostname (SNI) |
Whether or not to pass the hostname during the handshake for SNI (Server Name Indication). SNI is an extension of the TLS networking protocol that enables a client to include the hostname it is trying to connect to as part of the TLS handshake process. |
Cipher Suite Options
Cipher Suite |
Cipher Strings |
Encrypted |
All cipher suites are included except for the |
Encrypted & authenticated |
Refers to all cipher suites supported by OpenSSL that provide both encryption and authentication. This is achieved by including |
OpenSSL default |
Includes all the ciphers from the |
All (including unencrypted) |
Uses the |
An example of an adapter dropdown on a typical Windows laptop is shown below:
