WebSocket Client
WebSocket Client turns IO Ninja into a highly configurable raw WebSocket client-side terminal.
In IO Ninja, click the “New Session” dropdown and select “WebSocket Client”.
Type an address e.g.
wss://ws.postman-echo.com/rawand press “Connect”.
Press the “Ping” button and wait for a response to test connectivity.
Use the “Transmit” pane to send any packet to the connected WebSocket server.
Extra headers |
Specify extra headers for the WebSocket handshake. See Extra Headers section below for more information. |
Transmit mode |
Specify the WebSocket transmission mode. Transmission modes determine how the WebSocket client interprets and sends messages. See available options. |
Close mode |
Specify the WebSocket close mode. Close modes define how a connection is terminated. See available options. |
Graceful |
Close timeout |
Specify how long until a WebSocket timeout occurs. |
3000 |
Reconnect |
Attempt to reconnect when connection is dropped by the remote node. |
Reconnect timeout |
The delay between reconnect attempts. |
3000 (ms) |
Use local address |
Bind socket to the specified local address. |
Security level |
Specify OpenSSL security level. Read more about OpenSSL security levels here. |
1 |
Cipher suite |
Select an OpenSSL cipher mode. OpenSSL ciphers refer to the cryptographic algorithms supported by the OpenSSL library for securing data in transit, typically over SSL/TLS connections. Read more about OpenSSL ciphers here. See available options. |
ALL |
Use certificate |
Whether or not to use a certificate for the SSL connection. |
Certificate |
Specify the file path of the certificate. |
Private key |
Specify the private key for the certificate. |
Verify certificates |
Whether or not to verify the certificate of the target SSL server. |
CA certificate |
Specify the file path of the CA certificate to be used for verification. |
CA directory |
Specify a directory of CA certificates to be used for verification. |
Verify depth |
Specify the maximum certificate certificate chain length. A certificate chain is a sequence of certificates—starting with the SSL/TLS certificate and followed by one or more Certificate Authority (CA) certificates—that allows the recipient to verify the authenticity and trustworthiness of both the sender and the issuing CAs. |
10 |
Pass hostname (SNI) |
Whether or not to pass the hostname during the handshake for SNI (Server Name Indication). SNI is an extension of the TLS networking protocol that enables a client to include the hostname it is trying to connect to as part of the TLS handshake process. |
All SSL related options only apply when connecting to a secure WebSocket.
To connect to a secure WebSocket, prefix your address with wss:// instead of ws://.
Extra Headers
The “Extra headers” dictionary is a customizable set of HTTP headers sent during the WebSocket handshake request. Each entry is a key-value pair representing a header name and its value (e.g., Authorization: Bearer token123). These headers allow the client to include authentication tokens, session cookies, custom metadata, or protocol negotiation parameters, enhancing control and compatibility with secured or feature-rich WebSocket servers.
Transmit Mode Options
The plugin automatically determines whether to send the payload as text or binary based on its content. |
Text |
Forces the plugin to send all outgoing data as text frames. |
Binary |
Forces the plugin to send all outgoing data as binary frames. |
Close Mode Options
Graceful |
A graceful close follows the proper WebSocket protocol for connection termination. Both client and server exchange close frames, allowing for a clean shutdown. |
Abrupt |
An abrupt close terminates the WebSocket connection without sending a Close frame. |
Cipher Suite Options
Cipher Suite |
Cipher Strings |
Encrypted |
All cipher suites are included except for the |
Encrypted & authenticated |
Refers to all cipher suites supported by OpenSSL that provide both encryption and authentication. This is achieved by including |
OpenSSL default |
Includes all the ciphers from the |
All (including unencrypted) |
Uses the |
