TCP Server
The TCP Server plugin allows you to accept and manage incoming connections over TCP. It enables you to maintain multiple client connections at once, focus on specific client communications through filters, and gain full control over the TCP socket, like TCP Connection. This makes it an invaluable tool for troubleshooting and debugging client-side projects.
In IO Ninja, click the “New Session” dropdown and select “TCP Server”.
Set the adapter and port.
For example, if you wanted to listen for IPv4 traffic on port 2000, then you would set the adapter to “All IPv4 adapters” and the port to “2000”.
Click the “Listen” button to start listening to traffic.
Analyze the log as TCP requests are made to the server.
All IPv4 adapters |
An example of an adapter dropdown on a typical Windows laptop is shown below:
