TCP Proxy
The TCP Proxy plugin serves as an essential tool for inspecting data exchanged between two TCP nodes. Functioning as a man-in-the-middle, it offers a seamless way to monitor and log TCP communication, addressing common limitations encountered with traditional sniffing tools like the Pcap Sniffer plugin.
In IO Ninja, click the “New Session” dropdown and select “TCP Proxy”.
Set the target address, adapter and port.
For example, if you wanted to route IPv4 traffic on port 2000 to example.com, then you would set the target address to “example.com”, the adapter to “All IPv4 adapters” and the port to “2000”.
Click the “Listen” button to start intercepting traffic.
After initating connections to the proxy, intercepted traffic will show in the TCP Proxy window.
All IPv4 adapters |
Remote port to connect to in cases when a port is not explicitly specified in Remote address. |
80 |
An example of an adapter dropdown on a typical Windows laptop is shown below:
