UDP Socket
The UDP Socket plugin addresses connection-oriented communication challenges by enabling applications to communicate over a network without the need to establish traditional peer-to-peer connections. Operating in true connectionless mode, it allows a single UDP socket to efficiently interact with multiple remote nodes simultaneously, making it ideal for tasks like device discovery and broadcast messaging.
In IO Ninja, click the “New Session” dropdown and select “UDP Socket”.
Select a remote address (IP-address or hostname) and a local port to bind to for receiving packets. The local port is used once, when you click “Open Socket”, after that it is bound.
If the local port is set to 0, the OS will choose a free port.
The remote address can also include a port, such as “192.168.1.64:1001”. This port is used whenever you transmit, and you can modify it without reopening the socket.
Click the “Open Socket” button, to the right of the “Local port” selection field.
Analyze the log as UDP packets are received.
UDP Socket does more than just receive UDP packets, using the “Transmit” pane, it is easy to send packets too. You can specify a broadcast address, e.g., 255.255.255, or a subnet broadcast address such as 192.168.1.155 and send packets to a group of nodes at the same time.
Remote address (IP address or host name, optionally followed by a semicolon and a port). |
Remote port (if not specified in the remote address). |
Auto-switch remote address |
Automatically switch remote address upon receiving a datagram. |
All IPv4 adapters |
UDP broadcast |
Toggle whether or not to allow broadcast packets to be transmitted. |
An example of an adapter dropdown on a typical Windows laptop is shown below:
