namespace ui
namespace ui { // namespaces namespace ui.ComboBoxHistory; // typedefs typedef ui.ListItem ComboItem; typedef ui.ListItem EnumPropertyOption; // enums bitflag enum Alignment; enum AuthenticationMethod; bitflag enum ColorFlags; enum FileDlgKind; enum FilePropertyMode; bitflag enum FilePropertyOptions; bitflag enum FontFlags; enum FrameShadow; enum InsertActionPos; enum NetworkAdapterUsage; enum SizePolicy; bitflag enum SizePolicyFlags; enum StdColor; enum StdDlgButton; bitflag enum StdDlgButtons; enum StdDlgIcon; enum TextFormat; enum ToolButtonStyle; enum WebSocketCloseMode; enum WebSocketTransmitMode; // structs struct ColorRange; struct DictionaryEntry; struct FlagPropertyOption; struct HidDeviceEntry; struct ListItem; struct TextAttr; // classes class AbstractButton; class Action; class ActionProperty; class BoolProperty; class BoxLayout; class BufferPropertySet; class CheckBox; class CheckBoxLabel; class ChecksumInfoSet; class ColorProperty; class ColorRangeTree; class ComboBox; class ComboProperty; class DictionaryProperty; class DictionaryWidget; class EnumProperty; class FileDlg; class FileProperty; class FlagProperty; class FormLayout; class GroupBox; class GroupProperty; class HBoxLayout; class Icon; class InformationGrid; class InformationGroup; class InformationItem; class InformationStatValue; class InformationValue; class IntProperty; class Label; class Layout; class LineEdit; class ListWidget; class LogRecordCodeFilterUi; class LoginDlg; class Menu; class MessageDlg; class ProgressDlg; class Property; class PropertyGrid; class PushButton; class RadioButton; class SerialUi; class SocketPropertySet; class SpinBox; class SshPropertySet; class SslPropertySet; class StatusBar; class StatusPane; class StdEditToolBar; class StdSessionInfoSet; class StringProperty; class Terminal; class ThroughputInfoSet; class ToolBar; class VBoxLayout; class WebSocketUi; class Widget; // global variables ui.EnumPropertyOption const TransmitModeOptionTable[3] = { { "Auto", WebSocketTransmitMode.Auto }, { "Text", WebSocketTransmitMode.Text }, { "Binary", WebSocketTransmitMode.Binary }, }; string_t const TransmitModeToolTipTable[3] = { "Transmit as text if the packet is a valid UTF-8; transmit as binary otherwise", "Transmit as text always", "Transmit as binary always", }; ui.EnumPropertyOption CloseModeOptionTable[2] = { { "Graceful", WebSocketCloseMode.Graceful }, { "Abrupt", WebSocketCloseMode.Abrupt }, }; // global functions uint_t rgb( uint8_t r, uint8_t g, uint8_t b ); ui.DictionaryEntry* loadDictionary( doc.Storage* storage, string_t name, size_t* count = null ); void saveDictionary( ui.DictionaryEntry const* dictionary, doc.Storage* storage, string_t name ); ui.DictionaryEntry* insertDictionaryHead( ui.DictionaryEntry* dictionary, string_t key, string_t value, bool isChecked = true ); std.StringHashTable* createDictionaryHashTable(ui.DictionaryEntry const* dictionary); ui.DictionaryEntry* findDictionaryEntry( ui.DictionaryEntry* dictionary, string_t key ); bool isHidMonDeviceLess( io.HidMonDeviceDesc const* device1, io.HidMonDeviceDesc const* device2 ); void refreshHidMonDeviceListUi( ui.ComboBox* deviceCombo, ui.EnumProperty* deviceProp ); size_t findHidMonDeviceComboIndex( ui.ComboBox* deviceCombo, uint_t vid, uint_t pid, uint_t captureDeviceId = -1, uint_t address = -1, uint_t interfaceId = -1 ); bool isHidDeviceLess( ui.HidDeviceEntry const* device1, ui.HidDeviceEntry const* device2 ); void refreshHidDeviceListUi( ui.ComboBox* deviceCombo, ui.EnumProperty* deviceProp ); size_t findHidDeviceComboIndex( ui.ComboBox* deviceCombo, uint_t vid, uint_t pid, string_t path ); ui.EnumPropertyOption const* createPcapDeviceOptionArray(); ui.EnumProperty* createPcapDeviceProperty( ui.PropertyGrid* propertyGrid, ui.GroupProperty* group = null, ui.Property* beforeProp = null, string_t name, string_t toolTip ); ui.ComboBox* createPcapDeviceComboBox( ui.ToolBar* toolBar, uint_t width = -1 ); bool isSerialPortLess( io.SerialPortDesc const* port1, io.SerialPortDesc const* port2 ); void enumerateSerialPorts( ui.ComboBox* portCombo, ui.ComboProperty* portProp ); ui.EnumPropertyOption const* createNetworkAdapterOptionArray(ui.NetworkAdapterUsage usage); ui.EnumProperty* createNetworkAdapterProperty( ui.PropertyGrid* propertyGrid, ui.Property* group = null, ui.Property* insertBefore = null, ui.NetworkAdapterUsage usage, string_t name, string_t toolTip ); ui.EnumProperty* createNetworkAdapterProperty( ui.PropertyGrid* propertyGrid, ui.NetworkAdapterUsage usage, string_t name, string_t toolTip ); ui.ComboBox* createNetworkAdapterComboBox( ui.ToolBar* toolBar, ui.NetworkAdapterUsage usage, uint_t width = -1 ); io.SocketOptions getSocketOptions( ui.SocketPropertySet const* socketPropSet, ui.BufferPropertySet const* bufferPropSet ); bool isUsbMonDeviceLess( io.UsbMonDeviceDesc const* device1, io.UsbMonDeviceDesc const* device2 ); void refreshUsbMonDeviceListUi( ui.ComboBox* deviceCombo, ui.EnumProperty* deviceProp ); size_t findUsbMonDeviceComboIndex( ui.ComboBox* deviceCombo, uint_t vid, uint_t pid, uint_t captureDeviceId = -1, uint_t address = -1 ); bool isUsbDeviceLess( io.UsbDeviceEntry const* entry1, io.UsbDeviceEntry const* entry2 ); void refreshUsbDeviceListUi( ui.ComboBox* deviceCombo, ui.EnumProperty* deviceProp ); size_t findUsbDeviceComboIndex( ui.ComboBox* deviceCombo, uint_t vid, uint_t pid, uint_t bus = -1, uint_t address = -1 ); size_t findUsbInterfaceComboIndex( ui.ComboBox* interfaceCombo, uint_t interfaceId, uint_t altSettingId = -1 ); size_t findUsbEndpointComboIndex( ui.ComboBox* interfaceCombo, uint_t endpointId ); } // namespace ui
