BACnet MS/TP Analyzer
BACnet (Building Automation and Control Network) is a protocol used in building automation networks. The BACnet MS/TP Analyzer layer plugin can be attached to any Serial stream session for analysis of BACnet MS/TP frames traveling between BACnet MS/TP master and slave(s).
Ensure your serial device is connected to the computer that is running IO Ninja.
In IO Ninja, click the “New Session” dropdown and select a session type, e.g., “Serial”.
If not selected automatically, select your serial device from the “Port:” dropdown.
Open the port by clicking the “Open” button located to the right of the “Port:” dropdown.
Click the “Layer Pipelines” dropdown and select “BACnet MS/TP Analyzer”.
Analyze BACnet communications seamlessly inside your serial session.
