Serial Tap over SSH
The Serial Tap over SSH plugin extends the power of the IO Ninja Serial Tap to remote Linux devices, enabling monitoring of serial ports on machines like headless Raspberry Pi boards.
Prerequisites
Enabling SSH
On most Linux machines, SSH is enabled by default. However, if it is not, you will need to enable it.
On Raspbian and many other popular distros, you can perform the following command:
systemctl enable --now sshd
For other Linux distributions, please refer to their documentation.
Installing the Hardware Client
The Serial Tap over SSH plugin uses the IO Ninja Hardware Client (ioninja-hwc).
This hardware client needs to be installed and configured on the remote machine.
See Installing the Hardware Client for instructions.
Serial SSH’ing into your Linux Machine with IO Ninja
In IO Ninja, click the “New Session” dropdown and select a new “Serial Tap over SSH” session.
Type the host address of your remote Linux machine into the “Address:” field.
Many of these settings are also available in the “Control” pane for easy access.
Before capturing, you should select the proper baud rate (and other serial parameters).
Click the “Capture” button to the right of the “Address:” field to initiate a connection.
You will be prompted for SSH credentials.
Monitor your Serial Communications as Usual
See all communications in the Ninja Scroll Engine.
Remote port to connect to in cases when a port is not explicitly specified in Remote address. |
80 |
Use local address |
Bind socket to the specified local address. |
User name
User name for SSH authentication. |
User authentication
SSH authentication method (password or private key) |
Password |
Private key file
Private key file for SSH authentication (PEM format). |
Remember last password
Re-use the last entered password during subsequent connect attempts. |
Baud rate |
The serial baud rate. |
38400 bps |
Data bits |
Serial data bit count (word size). See available options. |
Parity |
Serial parity check type. See available options. |
Stop bits |
Serial stop bit count. See available options. |
1 bit |
Flip DTE/DCE |
Flip logical sides of the tap cable. All serial lines can be split into |
Data Bit Options
5 bits |
6 bits |
7 bits |
Parity Options
No parity bit is used |
Odd |
Odd parity (parity bit is set when the number of logical ones in the UART frame is odd). |
Even |
Even parity (parity bit is set when the number of logical ones in the UART frame is even). |
Mark |
Parity bit is present and always set. |
Space |
Parity bit is present and always clear. |
Stop Bit Options
1 bit |
1.5 bits |
2 bits |
