Ethernet Tap
This page is for the Ethernet Tap Tap plugin. For the board, see the hardware docs.
The Ethernet Tap is a hardware sniffer for monitoring Ethernet traffic flowing through a single Ethernet connection. The Tap passes the Ethernet traffic through with a delay equal to about 5.2uS. Use this plugin to monitor all its communications through the IO Ninja application.
In IO Ninja, click “New Session” and select a new “Ethernet” session.
If not selected automatically, select your Ethernet Tap from the “Tap:” dropdown.
If you can’t see your tap, press the “Refresh” button.
Click the “Capture” button to the right of the “Tap:” dropdown to start monitoring.
Analyze the log as needed.
Export to a .pcap file by pressing the “Export to .pcap” button.
The Ethernet Tap that should be used. |
Term to filter with when displaying packets. Packets filtered this way are still captured, but are just not shown in the log. You can see these filtered packets again by removing this filter. |
