Ethernet Tap over SSH
The Ethernet Tap over SSH plugin extends the power and simplicity the IO Ninja Ethernet Tap to remote Linux devices, enabling tapping of ethernet on devices like headless Raspberry Pi boards.
Prerequisites
Enabling SSH
On most Linux machines, SSH is enabled by default. However, if it is not, you will need to enable it.
On Raspbian and many other popular distros, you can perform the following command:
systemctl enable --now sshd
For other Linux distributions, please refer to their documentation.
Installing the Hardware Client
The Ethernet Tap over SSH plugin uses the IO Ninja Hardware Client (ioninja-hwc).
This hardware client needs to be installed and configured on the remote machine.
See Installing the Hardware Client for instructions.
SSH’ing into your Linux Machine with IO Ninja
In IO Ninja, click “New Session” and select a new “Ethernet Tap over SSH” session.
Type the host address of your remote Linux machine into the “Address:” field.
Click the “Capture” button to the right of the “Port:” field to initiate a connection.
You will be prompted for SSH credentials.
Analyze the log as needed.
Export to a .pcap file by pressing the “Export to .pcap” button.
Remote port to connect to in cases when a port is not explicitly specified in Remote address. |
80 |
Use local address |
Bind socket to the specified local address. |
User name
User name for SSH authentication. |
User authentication
SSH authentication method (password or private key) |
Password |
Private key file
Private key file for SSH authentication. |
Remember last password
Re-use the last entered password during subsequent connect attempts. |
Term to filter with when displaying packets. Packets filtered this way are still captured, but are just not shown in the log. You can see these filtered packets again by removing this filter. |
