I2C/SPI Tap
This page is for the I2C/SPI Tap Tap plugin. For the board, see the hardware docs.
The I2C/SPI Tap for IO Ninja is a hardware sniffer for monitoring I2C and SPI communications. Our sniffer allows you to tap into the lines of I2C and SPI links and immediately view the captured data bytes in IO Ninja software — in real time and using our innovative dual-hex view tailor-suited for the inherently full-duplex SPI data. Use this plugin to monitor all communications.
Ensure your I2C/SPI Tap is connected to your computer.
Please see the hardware documentation for guidance on doing so.
In IO Ninja, click the “New Session” dropdown and select a new “I2C/SPI Tap” session.
If not selected automatically, select your I2C/SPI Tap from the “Tap:” dropdown.
If you can’t see your tap, press the “Refresh” button.
Select either “SPI” or “I2C” from the “Protocol:” dropdown.
Start capturing by clicking the “Capture” button located to the right of the “Protocol:” dropdown.
Monitor communications in the “I2C/SPI Tap” tab.
Tap |
The I2C/SPI Tap that should be used. |
Protocol |
The protocol to be used, either |
SPI |
SPI mode |
Determines when data is sampled and shifted based on the clock polarity ( |
SPI-0 (CPOL 0, CPHA 0) |
SPI data bits |
Number of bits sent in each transaction from master to slave (or vice versa). See available options. |
SPI endianness |
The order in which individual bits within a byte or word are transmitted on the data line. See available options. |
Big-endian (MSBit first) |
Flip SPI MOSI/MISO |
Flip the |
Use update rate limit |
Only allow a specified number of log scroll operations per second. |
Update rate limit |
The number of log scroll operations allowed per second. |
16 |
SPI Mode Options
Clock starts low, data is read on rising edge. |
SPI-1 (CPOL 0, CPHA 1) |
Clock starts low, data is read on falling edge. |
SPI-2 (CPOL 1, CPHA 0) |
Clock starts high, data is read on falling edge. |
SPI-3 (CPOL 1, CPHA 1) |
Clock starts high, data is read on rising edge. |
SPI Data Bit Options
4 bits |
12 bits |
16 bits |
SPI Endianness Options
Little-endian (LSBit first) |
The least significant bit is transmitted first, meaning data is shifted out starting with the rightmost bit. This is less common and typically used only when a specific device requires it. |
The most significant bit is transmitted first, starting with the leftmost bit of the byte or word. This is the standard and most widely used format in SPI communications. |
