Ethernet Tap
This page is for the Ethernet Tap Tap board. For the plugin, see the plugin docs.
Ethernet Tap is an affordable sniffer for monitoring Ethernet traffic flowing through a single Ethernet connection. To monitor Ethernet traffic, an Ethernet cable that was initially connecting a switch (hub) to an Ethernet device is replaced by two Ethernet cables and the Ethernet Tap is inserted between them, in what is known as a “wedge” fashion. The Tap passes the Ethernet traffic through with a delay equal to about 5.2uS.
The Tap connects to your PC via a USB cable and is compatible with IO Ninja terminal/sniffer software.
Features
Designed for use with IO Ninja software (http://ioninja.com/).
Reliably captures
10Base-Tand100Base-TEthernet traffic [1] [2].Based on Intel MAX10 FPGA.
Six LEDs onboard:
Green Ready LED;
Green 100Mbps and yellow Link/Activity LEDs for the left
RJ45jack;Green 100Mbps and yellow Link/Activity LEDs for the right
RJ45jack;Blue Power LED.
High-speed (480Mbps) USB2.0 interface on a USB-C connector.
Supplied with a USB-C cable.
USB-powered, no additional external power necessary.
Compact, outside dimensions only 82 x 74 x 30 mm.
The product is field-upgradeable via the USB interface.
Connecting Ethernet Tap
Using the Ethernet Tap
Please see the documentation for the Ethernet Tap plugin.
Specifications
Ethernet Tap is supplied with a USB cable.
Hardware Specifications [3] [4]
Parameter |
Specification |
USB port |
USB 2.0, high-speed (480 MHz), USB-C connector |
Throughput |
Operating temperature |
0 to +60 degrees C |
Operating relative humidity |
10–90% |
Mechanical dimensions |
82 x 74 x 30 mm |
