Pipe Listener
Under Microsoft Windows, applications often perform IPC (inter-process communications) using named pipes. The Pipe Listener plugin lets you create a server-side pipe for the client to connect to, for testing named pipe communications.
For obvious reasons, this plugin is only available on Microsoft Windows.
