File Stream
In computing, a “file” is a fundamental Input/Output (IO) primitive offered by operating systems, representing an abstract device that supports standardized read and write operations. Beyond physical files on disk, this abstraction includes various IO endpoints such as named pipes (FIFOs in UNIX), windows mailslots, serial ports, device devices and other objects accessible via a filesystem names. The File Stream plugin facilitates direct interactions with these file-like objects.
In IO Ninja, click the “New Session” dropdown and select a new “File Stream” session
Enter the name of your file, e.g. a pipe or mailslot into the “File:” field.
For example, for the a pipe called “my-pipe-server”, you would type \\.\pipe\my-pipe-server.
Set the file access setting from the “Access:” dropdown menu.
Some devices are read-only, meaning they cannot be opened for writing. Mailslot files, for instance, can be opened in write-only mode because the server side of the mailslot is read-only. Similarly, if you want to simply dump data to a disk file, you must open it as write-only. Otherwise, IO Ninja will read the contents of the file and close it once the reading is complete.
Press the “Open” button to the right of the “File:” and “Access:” fields.
Communicate with the file as required using the Transmit pane.
File name |
Specify the file name to open. |
Access mode |
Access mode for the file, e.g., “Read/Write”, “Read-only”, and “Write-only”. |
Read/Write |
Read parallelism |
Maximum number of read requests to submit to |
The size of each individual read block submitted to |
