Serial port enumeration incomplete; cannot start capture
Using tdevmon for serial monitoring in x64 Windows 10, my virtual serial port does not appear in any of the dropdown selection lists. Manually entering "COM100" and attempting to start capture results in
Session started
Cannot start capture: The parameter is incorrect.
Several other similar solutions do list this COM100, and some others do not. Interacting with COM100 using e.g. YAT or PuTTY works well.
Greetings! The fact that IO Ninja doesn't enumerate this port on Windows means that its driver doesn't belong to the "Ports" device class:
Could you please share the .inf file for this driver? Or better yet, can you provide a download link for this virtual serial port driver so that we can play with it locally?
