ioninja-hwc: fragment captures
Hello!
Again I am capturing in a remote location, without good communications, using a simple raspberry and a Serial Tap. It is permanently capturing as we are trying to catch a "sporadic" issue.
As communications are bad, we are "chunking" the logs, in order to be able to download just the piece of log in which the issue eventually occurs. Now, we are chunking it "restarting" the ioninja-hwc process every 2 hours. It is easy using the systemd capabilities (using RuntimeMaxSec), but a side efect is that we have to set a minimun restart timeout (2 min), in order to avoid that the unit goes permantly disabled if a error happens (mainly, during installation, the raspberry is powered up before the serial tap is connected...).
Well, my point is, perhaps you could consider to add an option in the "ioninja-hwc" in order to allow "fragment" the logs (some similar, or simpler, to the opcions "-C" / "-G" available in tcpdump).
Regards!
Hello Josep,
I apologize once again for the delayed response 🙂
You’ve made a great point! The ability to auto-split the output file into volumes could indeed be very useful (and is also trivial to implement). We’ll include something like the --split command-line option in the next release of IO Ninja.
If you like, I can send you a link to an internal build of ioninja-hwc for arm64 once this feature is ready (before the official release). Let me know!
Hello again Vladimir,
Of course, if you could send me the internal build, I am still with the field device installed and I will tried it!
Thank you again 🙂
Regards !
Hello! Just a small additional remark, if possible/feasible/reasonable, consider the options of splitting by size (eg. each "n" MB) and by time (eg. each "t" minutes). It is just an idea... perhaps it seems more logic just consider the size, but -eg. for my case- it is more convenient to have captures of info more or less time aligned (eg. daily aligned... in fact, I am currently splitting them each 6 hours)
Regards!
Josep
Good point! Let's have settings for both!
Perfect! Thank you again. Regards
Here's an internal build of IO Ninja for arm64:
https://tibbo.com/downloads/archive/ioninja/.internal/prerelease/ioninja-5.7.1-c-linux-arm64.tar.xz
The ioninja-hwc introduces two new parameters:
--split-size <bytes> and --split-time <seconds>
Both options can be used together; in this case, the splitting will occur based on whichever condition is met first. Both options support reasonable suffixes, e.g., --split-size=10M, --split-time=6h, etc.
Let me know if this works for you!
