<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ioninja-hwc: fragment captures]]></title><description><![CDATA[<p dir="auto">Hello!<br />
Again I am capturing in a remote location, without good communications, using a simple raspberry and a Serial Tap. It is permanently capturing as we are trying to catch a "sporadic" issue.<br />
As communications are bad, we are "chunking" the logs, in order to be able to download just the piece of log in which the issue eventually occurs. Now, we are chunking it "restarting" the ioninja-hwc process every 2 hours. It is easy using the systemd capabilities (using RuntimeMaxSec), but a side efect is that we have to set a minimun restart timeout (2 min), in order to avoid that the unit goes permantly disabled if a error happens (mainly, during installation, the raspberry is powered up <em>before</em> the serial tap is connected...).</p>
<p dir="auto">Well, my point is, perhaps you could consider to add an option in the "ioninja-hwc" in order to allow "fragment" the logs (some similar, or simpler, to the opcions "-C" / "-G" available in tcpdump).</p>
<p dir="auto">Regards!</p>
]]></description><link>http://64.23.185.212/forum/topic/317/ioninja-hwc-fragment-captures</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Nov 2026 08:09:31 GMT</lastBuildDate><atom:link href="http://64.23.185.212/forum/topic/317.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Oct 2024 08:22:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ioninja-hwc: fragment captures on Tue, 24 Dec 2024 03:46:54 GMT]]></title><description><![CDATA[<p dir="auto">Hello Jose,</p>
<p dir="auto">Sure, no rush with the feedback -- please take your time.</p>
<p dir="auto">And thank you so much! Wishing you a Merry Christmas and a Happy New Year as well! Enjoy your winter holidays!</p>
]]></description><link>http://64.23.185.212/forum/post/732</link><guid isPermaLink="true">http://64.23.185.212/forum/post/732</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Tue, 24 Dec 2024 03:46:54 GMT</pubDate></item><item><title><![CDATA[Reply to ioninja-hwc: fragment captures on Fri, 20 Dec 2024 11:19:37 GMT]]></title><description><![CDATA[<p dir="auto">Hello. Thank you very much, Vladimir! Now it is <em>not</em> convenient to install this version in the field device, because just this days we have changed the "DUT" and it is important to acquire data in the same fashion that we have been doing it before. But, as soon as I can, I will try it and provide feedback.<br />
I take the opportunity of this post to wish you Merry Christmas! Regards</p>
]]></description><link>http://64.23.185.212/forum/post/731</link><guid isPermaLink="true">http://64.23.185.212/forum/post/731</guid><dc:creator><![CDATA[Jose Marro]]></dc:creator><pubDate>Fri, 20 Dec 2024 11:19:37 GMT</pubDate></item><item><title><![CDATA[Reply to ioninja-hwc: fragment captures on Mon, 16 Dec 2024 11:46:14 GMT]]></title><description><![CDATA[<p dir="auto">Here's an internal build of IO Ninja for arm64:</p>
<p dir="auto"><a href="https://tibbo.com/downloads/archive/ioninja/.internal/prerelease/ioninja-5.7.1-c-linux-arm64.tar.xz" rel="nofollow ugc">https://tibbo.com/downloads/archive/ioninja/.internal/prerelease/ioninja-5.7.1-c-linux-arm64.tar.xz</a></p>
<p dir="auto">The <code>ioninja-hwc</code> introduces two new parameters:</p>
<p dir="auto"><code>--split-size &lt;bytes&gt;</code> and <code>--split-time &lt;seconds&gt;</code></p>
<p dir="auto">Both options can be used together; in this case, the splitting will occur based on whichever condition is met first. Both options support reasonable suffixes, e.g., <code>--split-size=10M</code>, <code>--split-time=6h</code>, etc.</p>
<p dir="auto">Let me know if this works for you!</p>
]]></description><link>http://64.23.185.212/forum/post/730</link><guid isPermaLink="true">http://64.23.185.212/forum/post/730</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Mon, 16 Dec 2024 11:46:14 GMT</pubDate></item><item><title><![CDATA[Reply to ioninja-hwc: fragment captures on Wed, 11 Dec 2024 17:34:04 GMT]]></title><description><![CDATA[<p dir="auto">Perfect! Thank you again. Regards</p>
]]></description><link>http://64.23.185.212/forum/post/729</link><guid isPermaLink="true">http://64.23.185.212/forum/post/729</guid><dc:creator><![CDATA[Jose Marro]]></dc:creator><pubDate>Wed, 11 Dec 2024 17:34:04 GMT</pubDate></item><item><title><![CDATA[Reply to ioninja-hwc: fragment captures on Wed, 11 Dec 2024 09:48:33 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">if possible/feasible/reasonable, consider the options of splitting by size (eg. each "n" MB) and by time (eg. each "t" minutes). It is just an idea... perhaps it seems more logic just consider the size, but -eg. for my case- it is more convenient to have captures of info more or less time aligned (eg. daily aligned... in fact, I am currently splitting them each 6 hours)</p>
<p dir="auto">Good point! Let's have settings for both!</p>
]]></description><link>http://64.23.185.212/forum/post/724</link><guid isPermaLink="true">http://64.23.185.212/forum/post/724</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Wed, 11 Dec 2024 09:48:33 GMT</pubDate></item><item><title><![CDATA[Reply to ioninja-hwc: fragment captures on Sun, 08 Dec 2024 18:03:01 GMT]]></title><description><![CDATA[<p dir="auto">Hello! Just a small additional remark, if possible/feasible/reasonable, consider the options of splitting by size (eg. each "n" MB) and by time (eg. each "t" minutes). It is just an idea... perhaps it seems more logic just consider the size, but -eg. for my case- it is more convenient to have captures of info more or less time aligned  (eg. daily aligned... in fact, I am currently splitting them each 6 hours)<br />
Regards!<br />
Josep</p>
]]></description><link>http://64.23.185.212/forum/post/719</link><guid isPermaLink="true">http://64.23.185.212/forum/post/719</guid><dc:creator><![CDATA[Jose Marro]]></dc:creator><pubDate>Sun, 08 Dec 2024 18:03:01 GMT</pubDate></item><item><title><![CDATA[Reply to ioninja-hwc: fragment captures on Sat, 07 Dec 2024 12:49:21 GMT]]></title><description><![CDATA[<p dir="auto">Hello again Vladimir,<br />
Of course, if you could send me the internal build, I am still with the field device installed and I will tried it!<br />
Thank you again <img src="http://64.23.185.212/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=miq4h6da9ug" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" title=":-)" alt="🙂" /><br />
Regards !</p>
]]></description><link>http://64.23.185.212/forum/post/718</link><guid isPermaLink="true">http://64.23.185.212/forum/post/718</guid><dc:creator><![CDATA[Jose Marro]]></dc:creator><pubDate>Sat, 07 Dec 2024 12:49:21 GMT</pubDate></item><item><title><![CDATA[Reply to ioninja-hwc: fragment captures on Wed, 27 Nov 2024 06:24:51 GMT]]></title><description><![CDATA[<p dir="auto">Hello Josep,</p>
<p dir="auto">I apologize once again for the delayed response <img src="http://64.23.185.212/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=miq4h6da9ug" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" title=":)" alt="🙂" /></p>
<p dir="auto">You’ve made a great point! The ability to auto-split the output file into volumes could indeed be very useful (and is also trivial to implement). We’ll include something like the <code>--split</code> command-line option in the next release of IO Ninja.</p>
<p dir="auto">If you like, I can send you a link to an internal build of <code>ioninja-hwc</code> for arm64 once this feature is ready (before the official release). Let me know!</p>
]]></description><link>http://64.23.185.212/forum/post/707</link><guid isPermaLink="true">http://64.23.185.212/forum/post/707</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Wed, 27 Nov 2024 06:24:51 GMT</pubDate></item></channel></rss>
