Subscriptions
With a subscription you enable all IO Ninja capabilities at once. This is a convenient alternative to cherry-picking and buying capabilities one by one. It’s super-cheap, too — if you choose the annual subscription, you get all capabilities for as low as $5 per month!
Subscriptions enable all capabilities — even the one released after you subscribe!
You can unsubscribe at any time. After you unsubscribe, you will not be charged on the next billing cycle, but you still can use your subscription normally until the very end of the paid period.
Monthly vs Annual
We offer two subscription plans – monthly and annual. The only difference is the billing period and the price – annual is twice as cheap for the same subscription time. The next billing date is calculated based on the date of subscription (one month ahead or one year ahead).
You can switch between the subscription plans (monthly to annual or vice versa) at any time. When you switch plans, the next billing date is calculated on the date of plan change; the unused time of the previous subscription plan is returned to you in form of credits.
Borrowing Subscriptions
If you are a member of a workgroup, you also can borrow subscriptions – of course, if your workgroup has spare subscription seats available. From viewpoint of the IO Ninja application it will work just as if you are actually subscribed – everything becomes unlocked.
