Hello Josep,
Happy to see you are trying to play with the new Jancy feature! Indeed, dynamic layouts are replacing dynamic structs -- which never were utilized in IO Ninja (as they were way too limited for practical use).
With this new approach, it's possible to describe pretty much any protocol or protocol stack. Please check the release announcement; there, I outlined the main problems that dynamic layouts really help with, which boils down to this:
- auto-buffering (with pause-and-resume!)
- auto-advancing the "current" pointer as we declare fields
- auto-saving of all discovered fields
To answer your questions:
q1. is it possible to assign a value to a "dyfield"?
TLDR: currently, no. In theory, yes, but that (probably) would be a misuse.
The main motivation for dynamic layouts was a simplification of binary packet parsing. Therefore, jnc.DynamicLayout
expects a read-only void const*
as a buffer pointer, and the Jancy compiler adds an implicit const
to all fields to reinforce that.
In theory, it's possible to remove this limitation and allow passing non-const buffers to the dylayout
statement (thus allowing modification of dyfield
items). That shouldn't really break anything, but dynamic layouts won't really provide many benefits for the generation of packets (as opposed to parsing). The difference is that when we generate a packet, we outright know what has to be in the packet. So why not take a std.Buffer
and append
all the necessary blocks one by one?
q2. is it possible to access to the "DynamicLayout" elements outside of the dylayout section?
TLDR: yes and no (can enumerate all the fields, but can't reference a particular one by name or index).
Things like layout.myChar
are not possible, even in theory. What if there's the branch where myChar
is defined was simply skipped? Worse yet, what if myChar
's type depends on the branch, like:
dylayout (layout) {
dyfield uint8_t bitness;
switch (bitness) {
case 8:
dyfield uint8_t myChar;
break;
case 16:
dyfield uint16_t myChar;
break;
case 32:
dyfield uint32_t myChar;
break;
case 64:
dyfield uint64_t myChar;
break;
On the other hand, you can iterate over all the discovered fields after exiting from dylayout
-- that's what IO Ninja does to represent packets in the log. To do so, you pass jnc.DynamicLayoutMode.Save
to the jnc.DynamicLayout
constructor and then recursively walk over sections of jnc.DynamicLayout
Here's a rather lengthy but realistic example. To run it, simply glue all 3 code snippets below together.
First, let's define the protocol structures:
pragma(Alignment, 1);
struct EthernetHdr {
uint8_t m_dstMac[6];
uint8_t m_srcMac[6];
bigendian uint16_t m_etherType;
struct IpHdr {
uint8_t m_headerLength : 4;
uint8_t m_version : 4;
uint8_t m_typeOfService;
bigendian uint16_t m_totalLength;
bigendian uint16_t m_identification;
bigendian uint16_t m_flags : 3;
bigendian uint16_t m_fragmentOffset : 13;
uint8_t m_timeToLive;
uint8_t m_protocol;
bigendian uint16_t m_headerChecksum;
bigendian uint32_t m_srcAddress;
bigendian uint32_t m_dstAddress;
struct TcpHdr {
bigendian uint16_t m_srcPort;
bigendian uint16_t m_dstPort;
bigendian uint32_t m_seqNumber;
bigendian uint32_t m_ackNumber;
uint8_t m_reserved : 4;
uint8_t m_dataOffset : 4;
uint8_t m_flags;
bigendian uint16_t m_window;
bigendian uint16_t m_checksum;
bigendian uint16_t m_urgentData;
Now, here comes the main function. The dylayout
part is the heart of the parser. If you want pause-and-resume, you should put it into an async
coroutine -- then it will be possible to pause in the middle of parsing the packet if it's not complete yet -- and wait for more bytes. But for the TCP/IP stack, it won't make much sense, of course.
int main() {
// a sample packet
char packet[] =
0x"00 1d aa 5f 9c 68 00 ad 24 90 be ae 08 00 45 00"
0x"00 34 63 aa 40 00 80 06 00 00 c0 a8 01 79 14 bd"
0x"ad 18 83 53 01 bb 77 02 38 0b 00 00 00 00 80 02"
0x"fa f0 bc 0c 00 00 02 04 05 b4 01 03 03 08 01 01"
0x"04 02";
jnc.DynamicLayout layout(
jnc.DynamicLayoutMode.Save, // when parsing, also save all discovered fields
packet,
sizeof(packet)
dylayout (layout) { // the main specification
dyfield EthernetHdr hdr;
switch (hdr.m_etherType) {
case 0x0800: // IP4
dyfield IpHdr ipHdr;
ipHdr.m_protocol = 6;
if (ipHdr.m_headerLength * 4 > sizeof(IpHdr)) // have options
dyfield uint8_t options[sizeof(IpHdr) - ipHdr.m_headerLength * 4];
switch (ipHdr.m_protocol) {
case 6: // TCP
dyfield TcpHdr tcpHdr;
break;
case 17: // UDP
case 1: // ICMP
// etc
break;
case 0x86dd: // IPv6
case 0x0806: // ARP
// etc
printGroup(packet, layout);
return 0;
Finally, here's how to do a recursive walk across all discovered items. A more sophisticated version of such walker could be found in scripts/common/log_RepresentDynamicLayout.jnc
(it's used to render dynamic layouts in the log with respect for color, format specifier, display name, and other attributes):
string_t g_indentStep = " ";
void printGroup(
void const* p,
jnc.DynamicSectionGroup* group,
string_t indent = ""
for (size_t i = 0; i < group.m_sectionCount; i++) {
jnc.DynamicSection* section = group.m_sectionArray[i];
switch (section.m_sectionKind) {
case jnc.DynamicSectionKind.Array:
printf("%08x%s %s %s[%d]\n", section.m_offset, indent, section.m_type.m_typeString, section.m_decl.m_name, section.m_elementCount);
break;
case jnc.DynamicSectionKind.Struct:
jnc.StructType* type = dynamic (jnc.StructType*)section.m_type;
printFields(p, section.m_offset, type, indent);
break;
case jnc.DynamicSectionKind.Group:
printf("%08x%s %s {\n", section.m_offset, indent, section.m_decl.m_name);
printGroup(p, section, indent + g_indentStep);
printf("%s}\n", indent);
break;
void printFields(
void const* p,
size_t baseOffset, // struct field offsets are relative to the beginning of the struct, so we need base offset
jnc.StructType* type,
string_t indent
for (size_t i = 0; i < type.m_fieldCount; i++) {
jnc.Field* field = type.m_fieldArray[i];
size_t offset = baseOffset + field.m_offset;
printf("%08x%s %s %s", offset, indent, field.m_type.m_typeString, field.m_name);
if (field.m_type.m_typeKind != jnc.TypeKind.Struct)
printf(" = %s\n", field.getValueString(p + offset));
else {
printf("\n");
printFields(p, offset, dynamic (jnc.StructType*)field.m_type, indent + g_indentStep);
But what if you want to access a particular field instead of walking across all fields? Then you need to access it within dylayout
, from the branch where this field is visible! Otherwise, the field you try to access may be missing or be of the wrong type.
A short summary.
- dynamic layouts are for parsing binary packets; using them for packet generation is possible in theory, but gives (almost) no benefits compared to standard methods.
- a recursive walk across all discovered fields is possible -- IO Ninja does just that!
- accessing dynamic fields should be done from within
dylayout
, while we see the declaration and know the field is there.
I know, it's a lengthy reply, but hope this makes sense. Feel free to follow up with any questions or suggestions!
