Find Binary not working for hex values greater than 7F
Find Binary is not working to search a log file previously collected with Serial Tap. If I search for any hex value greater than 7F, then that data is not found, even though it is plainly visible in the log. This was working in an earlier version of IO Ninja on a different laptop, but I recently changed to a new laptop and installed the latest version, 5.4.1. Is there some configuration option that is forcing it to 7 bit ASCII, or is this a recently introduced bug?
Hello David,
Thank you for the bug report! The issue is confirmed, fixed, and staged for the very next official release. In the meantime, we can produce an internal build for you to try. Which target platform are you using IO Ninja on (Windows/Linux/macOS/amd64/x86/ARM)?
