tdevmon - segmentation fault
tdevmon should now build and work on new Aarch64 kernels -- with or without huge page support (ArchLinux kernel is built with it, Raspbian -- without).
Please try it and let me know:
https://tibbo.com/downloads/archive/tdevmon/tdevmon-3.3.11/tdevmon-3.3.11-linux-arm64.tar.xz
Re ioninja-hwc -- I wouldn't expect issues on Aarch64; it's a simple console app that does no platform-specific trickery.
A new internal build of IO Ninja for Aarch64 is up:
https://tibbo.com/downloads/archive/ioninja/.internal/prerelease/ioninja-5.3.1-b-linux-arm64.deb
https://tibbo.com/downloads/archive/ioninja/.internal/prerelease/ioninja-5.3.1-b-linux-arm64.tar.xz
Tried it on the latest ArchLinux -- it's working now.
Let me know if you notice any issues.
Hello Vladimir!,
I was going to tell you that I had tried the tdevmon and everything went smoothly: it builds ok, I was able to install the kernel module and the program works perfectly capturing data from the serial device.
And, then I found that you have already prepared the ioninja "main" program. I have quickly tried, and I found no problem 🙂
Thank you very much!
also, FYI, as I commented, I did this on a Rock64 plataform, with Arch Linux Arm. Eventually (soon), I will also tried it on a Raspberry. If I find any issue, I will tell you.
Regards, and thank you again!
