Your browser does not seem to support JavaScript. As a result, your viewing experience will be diminished, and you have been placed in read-only mode.
Please download a browser that supports JavaScript, or enable it if it's disabled (i.e. NoScript).
Hello,
How can I write a script for MODBUS to write on multiple register? Similar to the packet below, but in a scrip. I have a script for single register but I can't find the field "value" for multiple registers.
Code for single register:
ModbusRtuWritePacket packetWS; packetWS.initialize(); packetWS.m_adu.m_deviceAddress = addr; packetWS.m_pdu.m_func = io.ModbusFunc.WriteSingleRegister; packetWS.m_pdu.m_address = 0x1006; packetWS.m_pdu.m_value = 0x5501; packetWS.updateChecksum(); // Transmit the packet transmit(&packetWS, sizeof(packetWS));
Thanks for your help.
ModbusRtuWritePacket is from the legacy Modbus packet template library; it doesn't support multiple values per packet. The new Modbus plugin uses structures defined in scripts/protocols/io_Modbus.jnc. If you need to do it programmatically, just assemble your packet structure from necessary chunks (ADU hdr, PDU hdr, function-specific params, values, CRC). Important -- be sure to add pragma(Alignment, 1) as to avoid unintended struct paddings!
After the packet structure is defined, fill in the fields and calculate the checksum. Modbus RTU checksum is CRC16 ANSI (with init 0xffff) of the whole frame excluding the checksum itself.
0xffff
The full script listing is below:
import "io_Modbus.jnc" void main() { enum { DeviceAddress = 1, RegisterAddress = 0xA000, RegisterCount = 2, } pragma(Alignment, 1) struct MyPacket: io.ModbusRtuAduHdr, io.ModbusPduHdr, io.ModbusWriteMultipleParams { bigendian uint16_t m_registers[RegisterCount]; uint16_t m_crc; } MyPacket packet; packet.m_deviceAddress = DeviceAddress; packet.m_func = io.ModbusFunc.WriteMultipleRegisters; packet.m_address = RegisterAddress; packet.m_count = RegisterCount; packet.m_size = sizeof(packet.m_registers); packet.m_registers[0] = 123; packet.m_registers[1] = 456; // ... packet.m_crc = crc16_ansi(packet, offsetof(packet.m_crc), -1); transmit(packet, sizeof(packet)); }
@vladimir Thanks so much!
