Your browser does not seem to support JavaScript. As a result, your viewing experience will be diminished, and you have been placed in read-only mode.
Please download a browser that supports JavaScript, or enable it if it's disabled (i.e. NoScript).
Hi,
have some issues with an Alpha ESS PV Modbus attachment.
Alpha ESS --- Modbus RTU --- IO Ninja --- RTU <-> MODBUS TCP adapter <---- oModbus Master issues FN:3.
It's fine at the oModbus Master display, but the final setup is a Modbus RTU bridge over Modbus TCP. At this setup, I get communication errors.
Any idea what's wrong?
Thanks
Henri
Hmm, the log looks strange. Both TX and RX streams are there but contain exactly identical bytes of data.
Could you please provide more info on your setup? Is it RS232 or RS485? If it's the latter, is it a 2-wire (common) or 4-wire (much less common)? Also, a wiring diagram or a picture of how you connect your USB-to-Serial adapter would help.
Also, the screenshot doesn't show the configuration of your Modbus Analyzer (is it configured as half-duplex? What is the half-duplex timeout? etc.)
This KB article could help with configuring Modbus Analyzer for half-duplex: https://ioninja.com/doc/kb/modbus_half_duplex.html
