<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IDE installation on Linux and macOS]]></title><description><![CDATA[<p dir="auto">When I install the NetBeans IDE and the plugins on Windows, it seems to be ok, but if I install it on Linux or macOS and open an existing project, there are a lot of error indicators and a build generates the message "Cannot run program "/usr/bin/ioninja-server": error=2, No such file or directory". The IDE installation seems to be successful. What am I missing?</p>
<p dir="auto">Thank you.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1678487204486-linux_build.png" alt="linux_build.png" class=" img-responsive img-markdown" width="1255" height="1131" /></p>
]]></description><link>http://64.23.185.212/forum/topic/82/ide-installation-on-linux-and-macos</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 05:44:05 GMT</lastBuildDate><atom:link href="http://64.23.185.212/forum/topic/82.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 Mar 2023 22:31:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to IDE installation on Linux and macOS on Mon, 13 Mar 2023 21:16:04 GMT]]></title><description><![CDATA[<p dir="auto">That was it.</p>
<p dir="auto">On Ubuntu Linux using the .deb installer, the directory entries were:</p>
<p dir="auto">Binary Directory: /usr/bin<br />
Conf Directory: /usr/etc/ioninja</p>
<p dir="auto">On macOS using the .dmg installer, the directories were:</p>
<p dir="auto">Binary Directory: /Applications/IO Ninja.app/Contents/MacOS<br />
Conf Directory: /Applications/IO Ninja.app/Contents/Resources/conf</p>
<p dir="auto">Thanks,<br />
Mike</p>
]]></description><link>http://64.23.185.212/forum/post/283</link><guid isPermaLink="true">http://64.23.185.212/forum/post/283</guid><dc:creator><![CDATA[Mike Green]]></dc:creator><pubDate>Mon, 13 Mar 2023 21:16:04 GMT</pubDate></item><item><title><![CDATA[Reply to IDE installation on Linux and macOS on Sun, 12 Mar 2023 07:02:31 GMT]]></title><description><![CDATA[<p dir="auto">Be sure you specify the correct path to the IO Ninja installation location inside NetBeans settings:</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1678604286348-9319c0db-c1ba-4ed0-99c9-051f9bfd4699-image.png" alt="9319c0db-c1ba-4ed0-99c9-051f9bfd4699-image.png" class=" img-responsive img-markdown" width="1116" height="686" /></p>
<p dir="auto">The defaults are chosen to work out-of-the box for <code>.msi</code>, <code>.deb</code> or <code>.rpm</code> installers; for portable <code>.tar.xz</code> packages, however, you need to explicitly navigate to the installation directory.</p>
]]></description><link>http://64.23.185.212/forum/post/277</link><guid isPermaLink="true">http://64.23.185.212/forum/post/277</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Sun, 12 Mar 2023 07:02:31 GMT</pubDate></item></channel></rss>
