<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Monitor USB-serial traffic w&#x2F;o Serial-Tap]]></title><description><![CDATA[<p dir="auto">Is it possible to monitor traffic on a standard USB-serial device? I've had no luck getting results.</p>
<p dir="auto">This is on a mac.</p>
<p dir="auto">I am still in evaluation period, so all entitlements should be enabled.</p>
]]></description><link>http://64.23.185.212/forum/topic/70/monitor-usb-serial-traffic-w-o-serial-tap</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 23:39:46 GMT</lastBuildDate><atom:link href="http://64.23.185.212/forum/topic/70.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 05 Mar 2023 21:58:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Monitor USB-serial traffic w&#x2F;o Serial-Tap on Wed, 08 Mar 2023 02:14:56 GMT]]></title><description><![CDATA[<p dir="auto">I'm afraid the situation with the lack of a software Serial Monitor for macOS is not going to get fixed in the near future.</p>
<p dir="auto">Apple is pretty strict with security measures. Even well-established tools like <code>dtruss</code> are hard to run due to SIP (system integrity protection); an intercepting kernel module similar to ones we use on Windows and Linux for Serial Monitor would be nearly impossible to get <em>notarized</em> by Apple, and so on.</p>
<p dir="auto">So for the time being, capturing serial traffic on macOS can only be done at the physical layer using taps or USB-to-Serial adapters.</p>
]]></description><link>http://64.23.185.212/forum/post/260</link><guid isPermaLink="true">http://64.23.185.212/forum/post/260</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Wed, 08 Mar 2023 02:14:56 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor USB-serial traffic w&#x2F;o Serial-Tap on Mon, 06 Mar 2023 13:56:38 GMT]]></title><description><![CDATA[<p dir="auto">Is the lack of "Serial Monitor" plugin a temporary situation, or does Apple lock down everything so tight that getting traces is just impossible.</p>
<p dir="auto">I know that the dtruss (dtrace) doesn't see to function on my M1 Mac (while it still works on my same-version M68K laptop). Is it just the Apple tax for security?</p>
]]></description><link>http://64.23.185.212/forum/post/255</link><guid isPermaLink="true">http://64.23.185.212/forum/post/255</guid><dc:creator><![CDATA[Kent Hauser]]></dc:creator><pubDate>Mon, 06 Mar 2023 13:56:38 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor USB-serial traffic w&#x2F;o Serial-Tap on Mon, 06 Mar 2023 09:54:29 GMT]]></title><description><![CDATA[<p dir="auto">We currently don't have a software serial monitor for macOS.</p>
<p dir="auto">The <a href="/plugins/serial-monitor.html">Serial Monitor</a> plugin runs on Windows/Linux -- so if you can run your app on Windows/Linux and capture the traffic there, that's an option.</p>
<p dir="auto">Also, you can use a <a href="/hardware/serial-tap.html">Serial Tap</a> sniffer; no paid capabilities are required, and "Serial Tap" plugin is always enabled.</p>
<p dir="auto">For a half-duplex RS485 link, you can also use a second USB-to-RS485 adapter and read from it using the <a href="/plugins/serial.html">Serial</a> plugin.</p>
]]></description><link>http://64.23.185.212/forum/post/253</link><guid isPermaLink="true">http://64.23.185.212/forum/post/253</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Mon, 06 Mar 2023 09:54:29 GMT</pubDate></item></channel></rss>
