<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Baudrate &amp; Parity]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">I am quite new and I'm trying to set up some sensors with a plc.</p>
<p dir="auto">For it to work I need to change the parity and baud rate, so they correspond to the plc limitations and other Modbus devices that are connected. I have already managed to set different ID`s for the sensors but im not able to write the new Baud rate and parity.<br />
Baud from 38400 to 9600:<br />
<img src="/forum/assets/uploads/files/1677506433688-b9629ddb-aaba-44d7-b36d-f6cf5a425822-image.png" alt="b9629ddb-aaba-44d7-b36d-f6cf5a425822-image.png" class=" img-responsive img-markdown" width="1062" height="570" /><br />
Parity fom none to even:<br />
<img src="/forum/assets/uploads/files/1677506541485-5e5cb1f8-5b2f-4308-9668-ddb12053a484-image.png" alt="5e5cb1f8-5b2f-4308-9668-ddb12053a484-image.png" class=" img-responsive img-markdown" width="1067" height="564" /><br />
<img src="/forum/assets/uploads/files/1677506796122-4374386a-fa6b-4fe5-88fa-1a5ed2c2d029-image.png" alt="4374386a-fa6b-4fe5-88fa-1a5ed2c2d029-image.png" class=" img-responsive img-markdown" width="209" height="572" /></p>
<p dir="auto">Whenever I try I get error messages. How do you change them?</p>
]]></description><link>http://64.23.185.212/forum/topic/64/baudrate-parity</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 18:05:52 GMT</lastBuildDate><atom:link href="http://64.23.185.212/forum/topic/64.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Feb 2023 14:07:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Baudrate &amp; Parity on Thu, 02 Mar 2023 02:07:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://64.23.185.212/forum/uid/241">@Henry</a></p>
<p dir="auto">Please also check when you press the MD button, does the green LED turn ON?</p>
]]></description><link>http://64.23.185.212/forum/post/240</link><guid isPermaLink="true">http://64.23.185.212/forum/post/240</guid><dc:creator><![CDATA[Andrew Hsu]]></dc:creator><pubDate>Thu, 02 Mar 2023 02:07:23 GMT</pubDate></item><item><title><![CDATA[Reply to Baudrate &amp; Parity on Wed, 01 Mar 2023 10:18:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://64.23.185.212/forum/uid/241">@henry</a></p>
<p dir="auto">I have went through the process here to set the baudrate and parity as you have shown and can get it working.  I am thinking maybe this is related to the firmware inside the BP sensor. Please double check your frimware version; it should be 1.06 or later.  You can check it by checking register 121:</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1677665849567-0c4c35a9-008e-41eb-b71e-1667d71a80e9-image.png" alt="0c4c35a9-008e-41eb-b71e-1667d71a80e9-image.png" class=" img-responsive img-markdown" width="684" height="288" /></p>
<p dir="auto">If it is not, please follow the instructions from this page and see if the problem gets resolved.</p>
<p dir="auto"><a href="https://docs.tibbo.com/bp_updating_firmware" rel="nofollow ugc">https://docs.tibbo.com/bp_updating_firmware</a></p>
]]></description><link>http://64.23.185.212/forum/post/234</link><guid isPermaLink="true">http://64.23.185.212/forum/post/234</guid><dc:creator><![CDATA[Andrew Hsu]]></dc:creator><pubDate>Wed, 01 Mar 2023 10:18:08 GMT</pubDate></item><item><title><![CDATA[Reply to Baudrate &amp; Parity on Wed, 01 Mar 2023 08:11:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://64.23.185.212/forum/uid/241">@henry</a><br />
<img src="/forum/assets/uploads/files/1677658303824-2ffcbeda-32da-48fa-9f89-381c6820a821-image.png" alt="2ffcbeda-32da-48fa-9f89-381c6820a821-image.png" class=" img-responsive img-markdown" width="945" height="667" /></p>
]]></description><link>http://64.23.185.212/forum/post/233</link><guid isPermaLink="true">http://64.23.185.212/forum/post/233</guid><dc:creator><![CDATA[Henry]]></dc:creator><pubDate>Wed, 01 Mar 2023 08:11:50 GMT</pubDate></item><item><title><![CDATA[Reply to Baudrate &amp; Parity on Wed, 01 Mar 2023 07:47:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://64.23.185.212/forum/uid/174">@andrew-hsu</a><br />
Hi yes i have been holding the md button while sending the command until i get the error mesage<br />
I did manage to set the ID`s for the probes but when i try for the baud etc it doses not?<br />
iI did however spott somthing while looking at the registers, can this have somthing to do wit it.<br />
The id register does not have the (1)(2) behind it?<br />
<img src="/forum/assets/uploads/files/1677656799440-aefa9e38-9343-4eac-b824-23d12ca11b2d-image.png" alt="aefa9e38-9343-4eac-b824-23d12ca11b2d-image.png" class=" img-responsive img-markdown" width="1173" height="833" /></p>
]]></description><link>http://64.23.185.212/forum/post/232</link><guid isPermaLink="true">http://64.23.185.212/forum/post/232</guid><dc:creator><![CDATA[Henry]]></dc:creator><pubDate>Wed, 01 Mar 2023 07:47:19 GMT</pubDate></item><item><title><![CDATA[Reply to Baudrate &amp; Parity on Wed, 01 Mar 2023 07:38:37 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">The commands look correct.  If you refer to the documentation for the BP sensors, you will note that these two registers has the property of R/Wp.  This means that it is write-protected.  You will need to hold down the MD button on the BP sensor when you issue the commands for it to work.</p>
<p dir="auto"><a href="https://docs.tibbo.com/bp_registers" rel="nofollow ugc">https://docs.tibbo.com/bp_registers</a></p>
]]></description><link>http://64.23.185.212/forum/post/231</link><guid isPermaLink="true">http://64.23.185.212/forum/post/231</guid><dc:creator><![CDATA[Andrew Hsu]]></dc:creator><pubDate>Wed, 01 Mar 2023 07:38:37 GMT</pubDate></item></channel></rss>
