<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t unlock capabilities]]></title><description><![CDATA[<p dir="auto">Hi, I am a new user having just purchased a 12 month subscription. I am attempting to run the software on my iMac running macOS Ventura 13.2.1 (22D68).<br />
When I try to run a serial session I get:-</p>
<h2>The Serial plugin requires the following locked capabilities:<br />
org.jancy.io.serial<br />
To unlock capabilities, do either of the following:</h2>
<h2>Purchase these capabilities</h2>
<p dir="auto">Start an evaluation<br />
I have purchased a subscription so I expected it all to be unlocked.</p>
<p dir="auto">I also tried the evaluate option, and as soon as I click yes for the 14 day trial the program crashes.</p>
<p dir="auto">Help please.</p>
<p dir="auto">Thanks</p>
<p dir="auto">David</p>
]]></description><link>http://64.23.185.212/forum/topic/62/can-t-unlock-capabilities</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 21:24:15 GMT</lastBuildDate><atom:link href="http://64.23.185.212/forum/topic/62.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Feb 2023 06:25:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can&#x27;t unlock capabilities on Wed, 01 Mar 2023 10:33:07 GMT]]></title><description><![CDATA[<p dir="auto">Hello David,</p>
<p dir="auto">Oh, I see now. AppStore builds don't support subscriptions -- or any other purchases made outside of AppStore, for that matter. Alas, that's the policy of Apple only to allow In-App-Purchases for AppStore products.</p>
<p dir="auto">So, yes, please, just use a macOS package from the Download section on this site. Just FYI, AppStore builds also impose several other technical restrictions due to the required sandboxing (e.g., Pcap sniffer / TCP Flow / UDP Flow sessions can't be used, sessions can't be run as <code>sudo</code>, etc). So for macOS users, we actually recommend using non-AppStore builds (simply as more functional ones).</p>
]]></description><link>http://64.23.185.212/forum/post/235</link><guid isPermaLink="true">http://64.23.185.212/forum/post/235</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Wed, 01 Mar 2023 10:33:07 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t unlock capabilities on Fri, 24 Feb 2023 11:43:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi Vladimir,<br />
Interesting,I went to File, there was no settings listed, so I went to preferences and got the settings page, and then there was no 'My Account' so I decided to start again from square 1. I deleted the file, and this time downloaded it from your website (I downloaded it from Mac App Store last time). This time it started with a panel requesting how to log in which wasn't there before. It works now, not sure what happened previously. thank you for your prompt response.<br />
David</p>
]]></description><link>http://64.23.185.212/forum/post/225</link><guid isPermaLink="true">http://64.23.185.212/forum/post/225</guid><dc:creator><![CDATA[David]]></dc:creator><pubDate>Fri, 24 Feb 2023 11:43:01 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t unlock capabilities on Fri, 24 Feb 2023 10:00:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://64.23.185.212/forum/uid/235">@david</a>,</p>
<p dir="auto">I've just checked your account, and indeed you do have an annual subscription enabled. Everything in the app should be unlocked.</p>
<p dir="auto">If it isn't, it means that you either:</p>
<li>Didn't sign in to application under your account (e.g., you used GUEST account to sign into the app, and hence, only FREE capabilities are available)</li>
<p dir="auto">or</p>
<ol start="2">
<li>You use the OFFLINE sign-in, but didn't update the app token after purchasing a subscription (i.e., your app token doesn't have information about your subscription).</li>
<p dir="auto">To verify what is the case, please navigate to File-&gt;Settings-&gt;MyAccount:</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1677232719322-725095d5-a449-4941-b071-cded0d23da9b-image.png" alt="725095d5-a449-4941-b071-cded0d23da9b-image.png" class=" img-responsive img-markdown" width="639" height="592" /></p>
<p dir="auto">Hope this helps!</p>
]]></description><link>http://64.23.185.212/forum/post/224</link><guid isPermaLink="true">http://64.23.185.212/forum/post/224</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Fri, 24 Feb 2023 10:00:25 GMT</pubDate></item></channel></rss>
