<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Different between Serial Tap Pro and Serial Tap]]></title><description><![CDATA[<p dir="auto">What is the different between Serial Tap Pro and Serial Tap.</p>
]]></description><link>http://64.23.185.212/forum/topic/340/different-between-serial-tap-pro-and-serial-tap</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 23:08:30 GMT</lastBuildDate><atom:link href="http://64.23.185.212/forum/topic/340.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Dec 2025 17:37:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Different between Serial Tap Pro and Serial Tap on Mon, 15 Dec 2025 03:48:00 GMT]]></title><description><![CDATA[<p dir="auto">Hello Sunny,</p>
<p dir="auto">Serial Tap Pro is a next-generation serial sniffer; the functional differences that distinguish it from the original Serial Tap (<a href="https://ioninja.com/hardware/serial-tap.html" rel="nofollow ugc">https://ioninja.com/hardware/serial-tap.html</a>) are as follows.</p>
<p dir="auto">Serial Tap Pro features:</p>
<li>Galvanic isolation (for robustness and protection of all electrical circuits involved)</li>
<li>Twice as high baud rates (2.5 Mbps in Serial Tap Pro vs 1 Mbps in Serial Tap)</li>
<li>Automatic detection of baud rates and UART frame size (aka, ABR)</li>
<li>Guaranteed correct sequencing of all events with hardware-generated microsecond timestamps (in contrast, Serial Tap uses two independent USB-to-UART channels, timestamped at the PC side)</li>
<li>9-bit data frame support (used by some industrial equipment)</li>
<li>Half-duplex (two-wire) RS485 packet direction detection</li>
<li>Data and status line injection (so Serial Tap Pro can effectively be used in lieu of any USB-to-RS232/485/TTL adapter)</li>
<p dir="auto">Read more at the product page: <a href="https://ioninja.com/hardware/serial-tap-pro.html" rel="nofollow ugc">https://ioninja.com/hardware/serial-tap-pro.html</a></p>
]]></description><link>http://64.23.185.212/forum/post/778</link><guid isPermaLink="true">http://64.23.185.212/forum/post/778</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Mon, 15 Dec 2025 03:48:00 GMT</pubDate></item></channel></rss>
