<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New Serial Tap Pro not an option]]></title><description><![CDATA[<p dir="auto">Hello.</p>
<p dir="auto">Recently Purchased a Serial Tap Pro.  When inserting into a Win10 Pro laptop device manager correctly sees it as "IO Ninja Serial Tap Pro".  Device manager appears happy with the device.</p>
<p dir="auto">When i open Ioninja ver 5.7.5, Drop down to "IO ninja hardware", Serial Tap Pro is not an option, only Serial Tap.   If I select Serial Tap when it opens I don't have anything under the Tap: drop down.</p>
<p dir="auto">When I go to ioninja settings, My Account   I don't see serial tap pro listed. I only see  com.ioninja.io.serial-tap.  I am not sure if I should be seeing a serial-tap-pro Capability ID here?</p>
<p dir="auto">Any suggestions or help would be appreciated.</p>
<p dir="auto">Thanks</p>
<li>Jason</li>
]]></description><link>http://64.23.185.212/forum/topic/335/new-serial-tap-pro-not-an-option</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 09:12:28 GMT</lastBuildDate><atom:link href="http://64.23.185.212/forum/topic/335.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 17 Sep 2025 16:58:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New Serial Tap Pro not an option on Tue, 30 Sep 2025 06:00:58 GMT]]></title><description><![CDATA[<p dir="auto">Hello Jason,</p>
<p dir="auto">I've replied to this request over email, but let's cover it here, too -- in case anyone else bumps into a similar problem.</p>
<p dir="auto">Support for Serial Tap Pro was added recently, in <strong>IO Ninja 5.8.0</strong> -- therefore, please make sure that you are on a version higher than this. Generally speaking, you always want to be running the latest and greatest version of IO Ninja.</p>
<p dir="auto">Also, on Windows, for Serial Tap Pro and other hardware sniffers to function correctly, the official hardware driver is required. This driver is actually nothing more than a manifest telling Windows to use the system <code>winusb.sys</code> for devices with our VID/PIDs (vendor and product IDs). Nevertheless, this step is essential -- without it, IO Ninja won't be able to communicate with the taps (and taps will have an exclamation mark in Windows Device Manager).</p>
<p dir="auto">If you install IO Ninja via the "FULL" MSI installer, those drivers should be installed automatically. Otherwise (e.g., you prefer a portable <code>.7z</code> archive), please download drivers separately at Download -&gt; <a href="https://ioninja.com/downloads.html#ioninja-hw-drivers" rel="nofollow ugc">IO Ninja Hardware Drivers</a>; install them either (a) using <code>dpinst64</code>/<code>dpinst32</code> or (b) through the standard <em>Update Driver</em> process in Device Manager.</p>
<p dir="auto">After driver installation completes successfully, the taps in Device Manager should show no exclamation mark and use <code>winusb.sys</code> as a kernel-mode driver.</p>
]]></description><link>http://64.23.185.212/forum/post/769</link><guid isPermaLink="true">http://64.23.185.212/forum/post/769</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Tue, 30 Sep 2025 06:00:58 GMT</pubDate></item></channel></rss>
