<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Trouble capturing traffic using the Serial Monitor]]></title><description><![CDATA[<p dir="auto">I'm trying to use the evaluation copy to monitor serial activity on /dev/ttyUSB0. I  got the kernel module installed and ran the app and created a serial monitor session on /dev/ttyUSB0. I get the "Capture started on /dev/ttyUSB0" message when I start capture but I don't see any data displayed. I know my device is sending data because the LEDs on the USB to serial adapter are flashing. Also, my application that is using the serial port is working. Why wouldn't I see the captured data when I start capturing?</p>
<p dir="auto">I'm running on a Raspberry Pi 4.</p>
]]></description><link>http://64.23.185.212/forum/topic/30/trouble-capturing-traffic-using-the-serial-monitor</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 08:18:50 GMT</lastBuildDate><atom:link href="http://64.23.185.212/forum/topic/30.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Jun 2022 13:44:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Trouble capturing traffic using the Serial Monitor on Fri, 10 Jun 2022 13:25:13 GMT]]></title><description><![CDATA[<p dir="auto">Hmmm.. I installed <em>exactly</em> the same kernel as on your box:</p>
<pre><code>vladimir@raspberrypi:~ $ uname -a
Linux raspberrypi 5.15.32-v7+ #1538 SMP Thu Mar 31 19:38:48 BST 2022 armv7l GNU/Linux
<p dir="auto">Then overwritten the contents of <code>src/lkm</code> with the archive I uploaded earlier. It works!</p>
<pre><code>vladimir@raspberrypi:~/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm $ make
make -C /lib/modules/5.15.32-v7+/build/ M=/home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm modules
make[1]: Entering directory '/usr/src/linux-headers-5.15.32-v7+'
  CC [M]  /home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/module.o
  CC [M]  /home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/Device.o
  CC [M]  /home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/Hook.o
/home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/Hook.c: In function ‘Hook_stop’:
/home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/Hook.c:143:22: warning: suggest parentheses around ‘&amp;&amp;’ within ‘||’ [-Wparentheses]
  143 |   self-&gt;m_fops-&gt;read &amp;&amp; self-&gt;m_fops-&gt;read != Hook_fop_read ||
/home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/Hook.c:144:23: warning: suggest parentheses around ‘&amp;&amp;’ within ‘||’ [-Wparentheses]
  144 |   self-&gt;m_fops-&gt;write &amp;&amp; self-&gt;m_fops-&gt;write != Hook_fop_write ||
/home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/Hook.c:145:27: warning: suggest parentheses around ‘&amp;&amp;’ within ‘||’ [-Wparentheses]
  145 |   self-&gt;m_fops-&gt;read_iter &amp;&amp; self-&gt;m_fops-&gt;read_iter != Hook_fop_read_iter ||
/home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/Hook.c:146:28: warning: suggest parentheses around ‘&amp;&amp;’ within ‘||’ [-Wparentheses]
  146 |   self-&gt;m_fops-&gt;write_iter &amp;&amp; self-&gt;m_fops-&gt;write_iter != Hook_fop_write_iter ||
/home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/Hook.c:147:32: warning: suggest parentheses around ‘&amp;&amp;’ within ‘||’ [-Wparentheses]
  147 |   self-&gt;m_fops-&gt;unlocked_ioctl &amp;&amp; self-&gt;m_fops-&gt;unlocked_ioctl != Hook_fop_unlocked_ioctl ||
/home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/Hook.c:148:30: warning: suggest parentheses around ‘&amp;&amp;’ within ‘||’ [-Wparentheses]
  148 |   self-&gt;m_fops-&gt;compat_ioctl &amp;&amp; self-&gt;m_fops-&gt;compat_ioctl != Hook_fop_compat_ioctl
  CC [M]  /home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/Connection.o
  CC [M]  /home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/HashTable.o
  CC [M]  /home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/ScatterGather.o
  CC [M]  /home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/FileNameFilter.o
  CC [M]  /home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/lkmUtils.o
  CC [M]  /home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/stringUtils.o
  LD [M]  /home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/tdevmon.o
  MODPOST /home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/Module.symvers
  CC [M]  /home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/tdevmon.mod.o
  LD [M]  /home/vladimir/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm/tdevmon.ko
make[1]: Leaving directory '/usr/src/linux-headers-5.15.32-v7+'
vladimir@raspberrypi:~/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/share/tdevmon/src/lkm $ sudo insmod tdevmon.ko
vladimir@raspberrypi:~/Projects/ioninja/devmon/build/make-arm32/tdevmon-3.3.9-a-linux-arm32/bin $ sudo ./tdevmon -m /dev/ttyUSB0
Monitoring /dev/ttyUSB0 (module: usbserial), hit Ctrl+C to interrupt...
16:13:19.821 open
    pid:             2604
    tid:             2604
    result:          0
    file id:         00000000b902eb40
    flags:           00020241
    mode:            00000002
    file name:       /dev/ttyUSB0
16:13:19.821 write_iter
    pid:             2604
    tid:             2604
    result:          4
    offset:          0
    buffer size:     4
    data size:       4
    0000  61 62 63 0a                                      abc.
16:13:19.822 close
    pid:             2604
    tid:             2604
    result:          0
<p dir="auto">Are you sure you rebooted, or at the very least, removed the previous instance of <code>tdevmon.ko</code> via <code>rmmod</code> before testing? Also, please make sure you <em>overwrite</em> all source files, not simply unpack the archive into <code>src/lkm</code> (thus creating <code>src/lkm/lkm</code>).</p>
<p dir="auto">Actually, to make things more straightforward, here's a re-packaged patch:</p>
<p dir="auto"><a href="/forum/assets/uploads/files/1654867308614-tdevmon-3.3.9-a-linux-arm32.tar.gz">tdevmon-3.3.9-a-linux-arm32.tar.gz</a></p>
<p dir="auto">Please let me know if it works (again, reboot before testing).</p>
]]></description><link>http://64.23.185.212/forum/post/111</link><guid isPermaLink="true">http://64.23.185.212/forum/post/111</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Fri, 10 Jun 2022 13:25:13 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble capturing traffic using the Serial Monitor on Wed, 08 Jun 2022 14:32:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://64.23.185.212/forum/uid/2">@vladimir</a> Thanks!</p>
]]></description><link>http://64.23.185.212/forum/post/110</link><guid isPermaLink="true">http://64.23.185.212/forum/post/110</guid><dc:creator><![CDATA[David Betz]]></dc:creator><pubDate>Wed, 08 Jun 2022 14:32:05 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble capturing traffic using the Serial Monitor on Wed, 08 Jun 2022 13:43:48 GMT]]></title><description><![CDATA[<p dir="auto">OK, thanks. I will try to match your Raspbian as close as possible and see if I get it.</p>
]]></description><link>http://64.23.185.212/forum/post/109</link><guid isPermaLink="true">http://64.23.185.212/forum/post/109</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Wed, 08 Jun 2022 13:43:48 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble capturing traffic using the Serial Monitor on Wed, 08 Jun 2022 13:00:43 GMT]]></title><description><![CDATA[<p dir="auto">Here is the output of dmesg after the segfault.</p>
<p dir="auto">[   91.878302] tdevmon: hooking /dev/ttyUSB0 (fops: 9174bd4c)<br />
[   91.878332] 8&lt;--- cut here ---<br />
[   91.878347] Unable to handle kernel paging request at virtual address c0c48068<br />
[   91.878363] pgd = 2f6d8e2b<br />
[   91.878378] [c0c48068] *pgd=80000000007003, *pmd=40000000c0079d(bad)<br />
[   91.878421] Internal error: Oops: a0e [#1] SMP ARM<br />
[   91.878433] Modules linked in: exfat rfcomm cmac algif_hash aes_arm_bs crypto_simd cryptd algif_skcipher af_alg bnep hci_uart btbcm bluetooth ecdh_generic ecc snd_soc_hdmi_codec 8021q garp stp llc joydev ftdi_sio usbserial brcmfmac brcmutil v3d cfg80211 gpu_sched rfkill raspberrypi_hwmon i2c_brcmstb bcm2835_isp(C) bcm2835_v4l2(C) bcm2835_codec(C) snd_bcm2835(C) bcm2835_mmal_vchiq(C) v4l2_mem2mem videobuf2_vmalloc videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc vc_sm_cma(C) vc4 rpivid_mem cec drm_kms_helper snd_soc_core snd_compress snd_pcm_dmaengine snd_pcm snd_timer snd syscopyarea sysfillrect sysimgblt fb_sys_fops nvmem_rmem uio_pdrv_genirq uio sg tdevmon(O) i2c_dev drm fuse drm_panel_orientation_quirks backlight ip_tables x_tables ipv6<br />
[   91.878787] CPU: 3 PID: 1116 Comm: tdevmon Tainted: G         C O      5.15.32-v7l+ #1538<br />
[   91.878801] Hardware name: BCM2711<br />
[   91.878810] PC is at Hook_create+0x150/0x230 [tdevmon]<br />
[   91.878854] LR is at 0x0<br />
[   91.878863] pc : [&lt;bf192e74&gt;]    lr : [&lt;00000000&gt;]    psr: 40000013<br />
[   91.878873] sp : c2b03e70  ip : 00000020  fp : c2b03ea4<br />
[   91.878883] r10: 00000000  r9 : bf19a448  r8 : c341bcc8<br />
[   91.878891] r7 : c2b03eac  r6 : c0c48030  r5 : c0c480b0  r4 : c3534180<br />
[   91.878901] r3 : bf1935f8  r2 : 00000000  r1 : c0c480b0  r0 : c353418c<br />
[   91.878910] Flags: nZcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user<br />
[   91.878924] Control: 30c5383d  Table: 04a73b00  DAC: 55555555<br />
[   91.878932] Register r0 information: slab kmalloc-192 start c3534180 pointer offset 12 size 192<br />
[   91.878967] Register r1 information: non-slab/vmalloc memory<br />
[   91.878982] Register r2 information: NULL pointer<br />
[   91.878996] Register r3 information: 13-page vmalloc region starting at 0xbf191000 allocated at load_module+0xb94/0x2840<br />
[   91.879025] Register r4 information: slab kmalloc-192 start c3534180 pointer offset 0 size 192<br />
[   91.879057] Register r5 information: non-slab/vmalloc memory<br />
[   91.879070] Register r6 information: non-slab/vmalloc memory<br />
[   91.879082] Register r7 information: non-slab/vmalloc memory<br />
[   91.879095] Register r8 information: slab filp start c341bcc0 pointer offset 8<br />
[   91.879122] Register r9 information: 13-page vmalloc region starting at 0xbf191000 allocated at load_module+0xb94/0x2840<br />
[   91.879141] Register r10 information: NULL pointer<br />
[   91.879154] Register r11 information: non-slab/vmalloc memory<br />
[   91.879167] Register r12 information: non-paged memory<br />
[   91.879179] Process tdevmon (pid: 1116, stack limit = 0x3d367e2b)<br />
[   91.879190] Stack: (0xc2b03e70 to 0xc2b04000)<br />
[   91.879202] 3e60:                                     00000000 00c0079d 04400000 3391a86e<br />
[   91.879215] 3e80: c2b03ea4 c341bcc0 bf19a440 c341b300 c0c48030 00000000 c2b03ee4 c2b03ea8<br />
[   91.879226] 3ea0: bf191f04 bf192d30 c2b03ee4 00000000 bf196e98 3391a86e c2b03f34 40086d0b<br />
[   91.879238] 3ec0: c341b300 c4a73cc0 00000000 c341b300 be942270 00000003 c2b03f0c c2b03ee8<br />
[   91.879249] 3ee0: bf1929d4 bf191d50 be942270 3391a86e 40086d0b c1205048 0000000c 00000000<br />
[   91.879261] 3f00: c2b03fa4 c2b03f10 c046ca40 bf1928a8 ffffff9c 00000000 00000000 0005a094<br />
[   91.879272] 3f20: c2b02000 00000142 c2b03f94 c341b300 c045333c c04516f8 00000902 00000000<br />
[   91.879283] 3f40: 00000000 00000000 00000000 00000000 00000902 00000000 00000000 00000000<br />
[   91.879294] 3f60: 00000000 00000000 c2b03fac 3391a86e c02152e0 3391a86e b6f13500 be942270<br />
[   91.879306] 3f80: 0006f000 0000000c 00000036 c0200244 c2b02000 00000036 00000000 c2b03fa8<br />
[   91.879317] 3fa0: c0200040 c046c920 be942270 0006f000 00000003 40086d0b be942270 00000015<br />
[   91.879328] 3fc0: be942270 0006f000 0000000c 00000036 be942258 be9423b4 40086d0b 00000015<br />
[   91.879339] 3fe0: b6d8d1a0 be942224 00026298 b6d8d1ac 60000010 00000003 00000000 00000000<br />
[   91.879347] Backtrace:<br />
[   91.879359] [&lt;bf192d24&gt;] (Hook_create [tdevmon]) from [&lt;bf191f04&gt;] (Device_p_connectImpl+0x1c0/0x274 [tdevmon])<br />
[   91.879420]  r8:00000000 r7:c0c48030 r6:c341b300 r5:bf19a440 r4:c341bcc0<br />
[   91.879428] [&lt;bf191d44&gt;] (Device_p_connectImpl [tdevmon]) from [&lt;bf1929d4&gt;] (Device_fop_ioctl+0x138/0x3f0 [tdevmon])<br />
[   91.879484]  r10:00000003 r9:be942270 r8:c341b300 r7:00000000 r6:c4a73cc0 r5:c341b300<br />
[   91.879493]  r4:40086d0b<br />
[   91.879501] [&lt;bf19289c&gt;] (Device_fop_ioctl [tdevmon]) from [&lt;c046ca40&gt;] (sys_ioctl+0x12c/0xa20)<br />
[   91.879539]  r7:00000000 r6:0000000c r5:c1205048 r4:40086d0b<br />
[   91.879547] [&lt;c046c914&gt;] (sys_ioctl) from [&lt;c0200040&gt;] (ret_fast_syscall+0x0/0x1c)<br />
[   91.879564] Exception stack(0xc2b03fa8 to 0xc2b03ff0)<br />
[   91.879575] 3fa0:                   be942270 0006f000 00000003 40086d0b be942270 00000015<br />
[   91.879587] 3fc0: be942270 0006f000 0000000c 00000036 be942258 be9423b4 40086d0b 00000015<br />
[   91.879597] 3fe0: b6d8d1a0 be942224 00026298 b6d8d1ac<br />
[   91.879609]  r10:00000036 r9:c2b02000 r8:c0200244 r7:00000036 r6:0000000c r5:0006f000<br />
[   91.879617]  r4:be942270<br />
[   91.879629] Code: e284000c eb57f4d4 e30335f8 e34b3f19 (e5863038)<br />
[   91.879641] ---[ end trace a838db62019b3702 ]---<br />
[  326.926021] v3d fec00000.v3d: MMU error from client CLE (4) at 0x74a1000, pte invalid</p>
]]></description><link>http://64.23.185.212/forum/post/107</link><guid isPermaLink="true">http://64.23.185.212/forum/post/107</guid><dc:creator><![CDATA[David Betz]]></dc:creator><pubDate>Wed, 08 Jun 2022 13:00:43 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble capturing traffic using the Serial Monitor on Wed, 08 Jun 2022 12:54:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://64.23.185.212/forum/uid/2">@vladimir</a> Yes, this does give me a segfault. This is even after I installed the new kernel module you posted in your other message.</p>
]]></description><link>http://64.23.185.212/forum/post/106</link><guid isPermaLink="true">http://64.23.185.212/forum/post/106</guid><dc:creator><![CDATA[David Betz]]></dc:creator><pubDate>Wed, 08 Jun 2022 12:54:17 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble capturing traffic using the Serial Monitor on Tue, 07 Jun 2022 21:30:56 GMT]]></title><description><![CDATA[<p dir="auto">Please try replacing the kernel module sources in <code>share/tdevmon/src/lkm</code> with these:</p>
<p dir="auto"><a href="/forum/assets/uploads/files/1654637074663-lkm-src.tar.xz">lkm-src.tar.xz</a></p>
<p dir="auto">It looks like there's a bug in page protection removal code on ARM introduced in <code>tdevmon-3.3.9</code>...</p>
]]></description><link>http://64.23.185.212/forum/post/105</link><guid isPermaLink="true">http://64.23.185.212/forum/post/105</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Tue, 07 Jun 2022 21:30:56 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble capturing traffic using the Serial Monitor on Tue, 07 Jun 2022 19:18:03 GMT]]></title><description><![CDATA[<p dir="auto">Does it initially crash?</p>
<p dir="auto">Please reboot your Raspberry Pi, build and load <code>tdevmon.ko</code>, then, instead of running IO Ninja, navigate to <code>tdevmon-3.3.9-linux-arm32/bin</code> and run:</p>
<pre><code>$ ./tdevmon -m /dev/ttyUSB0
<p dir="auto">Will it segfault?</p>
]]></description><link>http://64.23.185.212/forum/post/104</link><guid isPermaLink="true">http://64.23.185.212/forum/post/104</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Tue, 07 Jun 2022 19:18:03 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble capturing traffic using the Serial Monitor on Tue, 07 Jun 2022 16:37:54 GMT]]></title><description><![CDATA[<p dir="auto">I get this far:</p>
<p dir="auto">Session started<br />
Capture started on /dev/ttyUSB0</p>
<p dir="auto">pi@raspberrypi:~ $ sudo tdevmon --version<br />
Tibbo Device Monitor v3.3.9 (arm32)<br />
Built on: Sep  6 2021 09:37:19</p>
<p dir="auto">Tibbo Device Monitor kernel module (arm32) v3.3.9<br />
Built on: Jun  3 2022 16:40:26</p>
<p dir="auto">pi@raspberrypi:~ $ uname -a<br />
Linux raspberrypi 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l GNU/Linux</p>
]]></description><link>http://64.23.185.212/forum/post/103</link><guid isPermaLink="true">http://64.23.185.212/forum/post/103</guid><dc:creator><![CDATA[David Betz]]></dc:creator><pubDate>Tue, 07 Jun 2022 16:37:54 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble capturing traffic using the Serial Monitor on Tue, 07 Jun 2022 13:36:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://64.23.185.212/forum/uid/108">@david-betz</a></p>
<p dir="auto">Hello David,</p>
<p dir="auto">Which version of <code>tdevmon</code> and which Raspbian (most importantly, the Linux kernel version) you are using?</p>
<pre><code>$ ./tdevmon --version
$ screenfetch
$ # or uname -a
<p dir="auto">When you run the "Serial Monitor" plugin, do you see notifications about port open/close (but no reads/writes)? Or no notifications about port activity at all?</p>
]]></description><link>http://64.23.185.212/forum/post/102</link><guid isPermaLink="true">http://64.23.185.212/forum/post/102</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Tue, 07 Jun 2022 13:36:57 GMT</pubDate></item></channel></rss>
