<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IO Ninja Serial Tap (Sniffer UART signal)]]></title><description><![CDATA[<p dir="auto">Hi IO Ninja Team:</p>
<p dir="auto">I recently purchased an IO Ninja Serial Tap to sniffer RS-232 and UART signal. (Good HW/SW quality, love it!)</p>
<p dir="auto">RS-232 sniffer looks good for me, but I'm in trouble when sniffer UART signal.</p>
<p dir="auto">What I do is:</p>
<li>Direct connect DB1 / DB2 connector's Tx, Rx, GND to my two UART devices separately.</li>
<li>Select switch to UART (TTL)</li>
<li>Open software and start to monitor.</li>
<p dir="auto">Then I see nothing on software.<br />
Kindly is my configuration correct? If not, what's the right configuration, thanks~~~</p>
]]></description><link>http://64.23.185.212/forum/topic/29/io-ninja-serial-tap-sniffer-uart-signal</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 23:09:44 GMT</lastBuildDate><atom:link href="http://64.23.185.212/forum/topic/29.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 01 Jun 2022 04:25:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to IO Ninja Serial Tap (Sniffer UART signal) on Sun, 05 Jun 2022 14:04:37 GMT]]></title><description><![CDATA[<p dir="auto">Dear Valdimir:</p>
<p dir="auto">This definitely help.  I will give it a try and see what's the result. Thanks mate!</p>
]]></description><link>http://64.23.185.212/forum/post/100</link><guid isPermaLink="true">http://64.23.185.212/forum/post/100</guid><dc:creator><![CDATA[James YT Chen陳盈佐]]></dc:creator><pubDate>Sun, 05 Jun 2022 14:04:37 GMT</pubDate></item><item><title><![CDATA[Reply to IO Ninja Serial Tap (Sniffer UART signal) on Thu, 02 Jun 2022 20:00:30 GMT]]></title><description><![CDATA[<p dir="auto">Hi James,</p>
<p dir="auto">Glad you enjoy the quality of our HW/SW, thanks for the feedback!</p>
<p dir="auto">Now, to your question. When you use a Serial Tap to sniff TTL-level UART signal, you <em>have to</em> use the terminal block on top of your Serial Tap, not DB9 connects at the sides.</p>
<p dir="auto">As can be seen from this <a href="https://ioninja.com/doc/hw/index.html?st_diagram.htm" rel="nofollow ugc">block diagram</a>, DB9 connectors are for RS232 only; RS485 and UART(TTL) lines can only be connected the corresponding section of the terminal block.</p>
<p dir="auto">Hope this helps!</p>
]]></description><link>http://64.23.185.212/forum/post/97</link><guid isPermaLink="true">http://64.23.185.212/forum/post/97</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Thu, 02 Jun 2022 20:00:30 GMT</pubDate></item></channel></rss>
