<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Trying to Snoop an RS485 link - Port problems]]></title><description><![CDATA[<p dir="auto">I don't know where to look to set the respective ports.  Port A and B?<img src="/forum/assets/uploads/files/1632599177469-85aa3448-0740-49fa-ba19-b2da7ff5d804-image.png" alt="85aa3448-0740-49fa-ba19-b2da7ff5d804-image.png" class=" img-responsive img-markdown" width="716" height="262" /></p>
]]></description><link>http://64.23.185.212/forum/topic/15/trying-to-snoop-an-rs485-link-port-problems</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 19:53:01 GMT</lastBuildDate><atom:link href="http://64.23.185.212/forum/topic/15.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 25 Sep 2021 19:46:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Trying to Snoop an RS485 link - Port problems on Fri, 01 Oct 2021 02:23:11 GMT]]></title><description><![CDATA[<p dir="auto">Could you please share your wiring diagram? Or a photo of how you connect the tap?</p>
<p dir="auto">For RS485 half-duplex (two-wire), you need to connect either the (RX+/RX-) pair or the (TX+/TX-) pair. The only difference it's going to make is how the data will be <em>called</em> in the IO Ninja log -- RX or TX.  For RS485 full-duplex (four-wire) -- which is far less common -- you need to connect both (RX+/RX-) and (TX+/TX-).  But you definitely don't need two taps to sniff a single serial link.</p>
]]></description><link>http://64.23.185.212/forum/post/47</link><guid isPermaLink="true">http://64.23.185.212/forum/post/47</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Fri, 01 Oct 2021 02:23:11 GMT</pubDate></item><item><title><![CDATA[Reply to Trying to Snoop an RS485 link - Port problems on Thu, 30 Sep 2021 16:29:58 GMT]]></title><description><![CDATA[<p dir="auto">Hi Vladimr, I was playing around a little more with your Serial Tap and note the following:<br />
When I only connected the TX+ on your Tap the Modbus Analyzer recognizes both my Master request and my Slave's response.  This is perfect and just what I wanted.</p>
<p dir="auto">I am a little confused as to why the RX lines were not reading the data as I expected?</p>
]]></description><link>http://64.23.185.212/forum/post/46</link><guid isPermaLink="true">http://64.23.185.212/forum/post/46</guid><dc:creator><![CDATA[Walter Danti]]></dc:creator><pubDate>Thu, 30 Sep 2021 16:29:58 GMT</pubDate></item><item><title><![CDATA[Reply to Trying to Snoop an RS485 link - Port problems on Thu, 30 Sep 2021 16:03:15 GMT]]></title><description><![CDATA[<p dir="auto">Thank you Vladimir, that has worked.  I do have a question related to Modbus data transmitted and received:<br />
When I attached both the RX+ and RX- between my Master and Slave devices I only receive my Slave's response and the Modbus analyzer recognizes this.  When I only keep the RX+ line connected I receive both thee Masteer and Slave data strings but the Modbus Analyzer does not recognize this.  Am I doing something wrong or would I need a second IONinja Serial Tap to read both Masteer and Slave strings?</p>
]]></description><link>http://64.23.185.212/forum/post/45</link><guid isPermaLink="true">http://64.23.185.212/forum/post/45</guid><dc:creator><![CDATA[Walter Danti]]></dc:creator><pubDate>Thu, 30 Sep 2021 16:03:15 GMT</pubDate></item><item><title><![CDATA[Reply to Trying to Snoop an RS485 link - Port problems on Tue, 28 Sep 2021 15:45:49 GMT]]></title><description><![CDATA[<p dir="auto">Oh, so you are using a Serial Tap for IO Ninja; not a generic dual-COM serial tap.</p>
<p dir="auto">Then you need to use a dedicated "Serial Tap" plugin (not "Generic Serial Tap").</p>
]]></description><link>http://64.23.185.212/forum/post/43</link><guid isPermaLink="true">http://64.23.185.212/forum/post/43</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Tue, 28 Sep 2021 15:45:49 GMT</pubDate></item><item><title><![CDATA[Reply to Trying to Snoop an RS485 link - Port problems on Mon, 27 Sep 2021 14:51:19 GMT]]></title><description><![CDATA[<p dir="auto">I set up my serial Tap as you recommended in a previous post (RX+ and RX- on the TAP) and set up Buad rates etc to suit.  Started the Snooping tool but got the Port messages above.  What settings do I need to set to read both RX+ and RX- data?</p>
]]></description><link>http://64.23.185.212/forum/post/42</link><guid isPermaLink="true">http://64.23.185.212/forum/post/42</guid><dc:creator><![CDATA[Walter Danti]]></dc:creator><pubDate>Mon, 27 Sep 2021 14:51:19 GMT</pubDate></item><item><title><![CDATA[Reply to Trying to Snoop an RS485 link - Port problems on Mon, 27 Sep 2021 06:27:50 GMT]]></title><description><![CDATA[<p dir="auto">Generic serial tap reads from two ports at the same time -- one port obtains RX, CTS, DSR; the second one obtains TX, DTR, RTS. Oftentimes, only TX and RX are required -- it simplifies the wiring. There are various over-the-counter dual-COM taps available; you can easily solder (or build on a breadboard) your own one, too.</p>
<p dir="auto">The log error message says "ports A and B" while the toolbar refers to those ports as "DTE" and "DCE". This is confusing, I agree. We will change the port names in the log to "DTE" and "DCE" for consistency.</p>
]]></description><link>http://64.23.185.212/forum/post/41</link><guid isPermaLink="true">http://64.23.185.212/forum/post/41</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Mon, 27 Sep 2021 06:27:50 GMT</pubDate></item></channel></rss>
