<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[log granularity]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I'm in conflit with io board log and log coming from an other log sw.<br />
My concern is about the races "Trigger:c,1Trigger:C,0...." at the timestamp +54:22.656<br />
How much I'm sure date on this line are coming in this close timing<br />
Other log SW give about 300ms between all "Trigger" messages</p>
<p dir="auto">Thank you</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1686038277213-io-granularity.png" alt="io granularity.png" class=" img-responsive img-markdown" width="838" height="166" /></p>
]]></description><link>http://64.23.185.212/forum/topic/146/log-granularity</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 06:29:22 GMT</lastBuildDate><atom:link href="http://64.23.185.212/forum/topic/146.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Jun 2023 08:01:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to log granularity on Tue, 20 Jun 2023 01:30:16 GMT]]></title><description><![CDATA[<p dir="auto">Hi Thierry,</p>
<p dir="auto">By default, IO Ninja merges both RX (green) and TX (blue) data blocks to produce a more easy-to-follow log (the white-and-gray checker pattern background shows block boundaries). The timestamp shown on the left is the timestamp of the last block in this particular line.</p>
<p dir="auto">You can also turn off merging altogether (Settings -&gt; Log Engine -&gt; Binary Data -&gt; Merge -&gt; Never) -- then each received block will be shown on a separate line, and you will see the timestamp of each block on the left.</p>
]]></description><link>http://64.23.185.212/forum/post/418</link><guid isPermaLink="true">http://64.23.185.212/forum/post/418</guid><dc:creator><![CDATA[Vladimir]]></dc:creator><pubDate>Tue, 20 Jun 2023 01:30:16 GMT</pubDate></item></channel></rss>
