Trying to Snoop an RS485 link - Port problems
I don't know where to look to set the respective ports. Port A and B?85aa3448-0740-49fa-ba19-b2da7ff5d804-image.png
Generic serial tap reads from two ports at the same time -- one port obtains RX, CTS, DSR; the second one obtains TX, DTR, RTS. Oftentimes, only TX and RX are required -- it simplifies the wiring. There are various over-the-counter dual-COM taps available; you can easily solder (or build on a breadboard) your own one, too.
The log error message says "ports A and B" while the toolbar refers to those ports as "DTE" and "DCE". This is confusing, I agree. We will change the port names in the log to "DTE" and "DCE" for consistency.
I set up my serial Tap as you recommended in a previous post (RX+ and RX- on the TAP) and set up Buad rates etc to suit. Started the Snooping tool but got the Port messages above. What settings do I need to set to read both RX+ and RX- data?
Oh, so you are using a Serial Tap for IO Ninja; not a generic dual-COM serial tap.
Then you need to use a dedicated "Serial Tap" plugin (not "Generic Serial Tap").
Thank you Vladimir, that has worked. I do have a question related to Modbus data transmitted and received:
When I attached both the RX+ and RX- between my Master and Slave devices I only receive my Slave's response and the Modbus analyzer recognizes this. When I only keep the RX+ line connected I receive both thee Masteer and Slave data strings but the Modbus Analyzer does not recognize this. Am I doing something wrong or would I need a second IONinja Serial Tap to read both Masteer and Slave strings?
Hi Vladimr, I was playing around a little more with your Serial Tap and note the following:
When I only connected the TX+ on your Tap the Modbus Analyzer recognizes both my Master request and my Slave's response. This is perfect and just what I wanted.
I am a little confused as to why the RX lines were not reading the data as I expected?
Could you please share your wiring diagram? Or a photo of how you connect the tap?
For RS485 half-duplex (two-wire), you need to connect either the (RX+/RX-) pair or the (TX+/TX-) pair. The only difference it's going to make is how the data will be called in the IO Ninja log -- RX or TX. For RS485 full-duplex (four-wire) -- which is far less common -- you need to connect both (RX+/RX-) and (TX+/TX-). But you definitely don't need two taps to sniff a single serial link.
