HID Terminal
The HID Terminal plugin is a powerful tool designed for direct low-level communication with Human Interface Devices (HID). HID devices, such as keyboards, mice, and card readers, operate over USB or Bluetooth and share unique properties. The HID Terminal plugin leverages these properties to provide a streamlined and efficient way to interact with HID devices.
In IO Ninja, click the “New Session” dropdown and select a new “HID” session
From the “Device:” dropdown menu, select the HID device you want to communicate with.
Click the “Open” button, to the right of the device selection dropdown.
In the “Control” pane, send and receive as needed to communicate with your HID device.
Adjust settings as needed via the “Settings” button (see “Settings” section below for details)
Output & Feature Requests
With HID devices, output reports are used to send immediate commands, such as setting LED states, typically transmitted over an interrupt OUT endpoint for real-time control, while feature reports are employed for configuration, status queries, or extended device-specific functions, exchanged over the control endpoint via requests, allowing bidirectional communication for settings that are less time-critical. IO Ninja employs a “Control” pane that lets you select HID output and feature reports, receive current values, and alter the values of individual properties.
The HID device to be monitored. |
Read mode |
Specify the HID input report mode. Useful as a bypass for devices that don’t allow reading of HID communications. See available options. |
Normal (read) |
Read Mode Options
Mode |
Normal (read) |
Read the HID device communications normally. |
Disabled (don’t read) |
Disable reading of the HID device communications. |
